How can I tell if my MAP sensor has gone bad?
There is no CEL for it but my Map sensor has been reading boost. I have a missing link and it still reads boost. So I put 7 check valves in line with the MAP and Missing link and it still reads boost. I think it is the map sensor. When I first turbo'd my teg I had the check valves wrong and I think my MAP read about 10 psi. Could this have F*@#% it up?
i run 10psi daily on a stock honda map sensor with no problems whatsoever.
if the map sensor was messed up, it would throw a check engine light, and also, if it was seeing boost without a chipped ECU, it would throw a check engine light.
If there is no check engine light, its not seeing boost.
The stock map sensor can read up to .75bar gauge. People here who are running hondata or uberdata, etc... show their map sensor boost all the time. with the stock setup, it's not the sensor that's the problem, its' that the ECU does not have fuel/ignition maps for positive manifold pressure. If you're not getting a CEL don't worry about the sensor, worry about other things though if you were seeing boost on stock maps.
I HAVE ALMOST THE SAME PROBLEM, SOME TIMES WHEN IM DRIVING MY BOOST GAUGE READS FULL BOOST OR THE BOOST BUILDS UP WAY TO QUICKLY AND THE CARS SMOKES AND ITS DOESNT WANTA PAST 30 MPH, THE GUY I BOUGHT IT FROM SAID ITS A SENOR BAD, IM THINKING OF PUTING A BOOST CONTROLLER IN GUYS , HELP ME OUT WHAT SHOULD I DO?
B16Civic93
Apr 2, 2005 09:39 AM
HybridCoupe
Jul 1, 2002 09:55 AM
