Spark plug gapping???
Old Oct 1, 2001 | 10:05 PM
DelsolVtec18's Avatar
New User
Default Spark plug gapping???
What is the spark plug supposed to be gapped to on a ITR???
Old Oct 1, 2001 | 10:32 PM
PrjctDC2-R's Avatar
New User
Default Re: Spark plug gapping??? (DelsolVtec18)
.044
Old Oct 3, 2001 | 02:06 PM
itrhybrid's Avatar
Default Re: Spark plug gapping??? (PrjctDC2-R)
I've heard that 1-1.1mm is correct also. Any truth?
I just got my PFR6G-11's in the mail today. Can anyone tel me if they need to be gapped or not? I don't have a way of checking.
Thanks
James
[Modified by itrhybrid, 4:12 PM 10/3/2001]
Old Oct 3, 2001 | 03:23 PM
FBP_1171's Avatar
Default Re: Spark plug gapping??? (itrhybrid)
I always say to check your plugs just to be sure, but every NGK I've ever checked has been right on the money.
Old Oct 3, 2001 | 03:36 PM
JSIR's Avatar
New User
Default Re: Spark plug gapping??? (FBP_1171)
I've always thought that Type R's use 1.3mm gaps (1.2 + or - .1 mm) from the factory, same as GSR's and SiR's. That relates to .051" . So 1.1mm (.044") would be on the low side of the spec.
Joey
Old Oct 3, 2001 | 03:41 PM
len's Avatar
len
Default Re: Spark plug gapping??? (JSIR)
A tip my dad told me:
Set the gap with a wire gauge. Not a sliding guage that can crack the electrode or the porcelian.
Honda's Civic come with 0.040 fresh from the factory. I'm not sure about the ITR's.
[Modified by ILOVERACING, 7:43 PM 10/3/2001]
Old Oct 3, 2001 | 05:49 PM
JSIR's Avatar
New User
Default Re: Spark plug gapping??? (ILOVERACING)
the Civic Si/R comes with 1.3mm plugs, as the last two digits of the plug code are 13, same spec as ITR and GSR, the SOHC Civics use 1.1mm plugs (last two digits of plug code are 11). There is also a label underhood that lists the spec range.
Joey
Chiller
Oct 29, 2004 08:18 AM
krazn
Sep 25, 2004 04:03 PM
JinDIESEL
Sep 18, 2004 09:36 PM
Toptul_Honda
Oct 14, 2002 06:27 PM
silvercivicsir
Feb 18, 2002 02:36 AM
