Air Fuel Ratio
Nothing special at all, knowing how to find a ACC 12VDC+ from the fuse box, a nice ground, and where your oxygen sensor is... Besides that it's pretty straight forward, if you know how to read ECU pinouts that definately helps because it allows you to tap your A/F meters signal line inside the car instead of running a wire out to the engine bay... Either way you're on the same line, I'm just extremely picky about wiring, etc... Good Luck
