Radiator Fan -- STUMPED
Old Jan 20, 2004 | 05:54 AM
dustinsterk's Avatar
Default Radiator Fan -- STUMPED
Okay, I have replaced the thermostat, the thermo switch, blead coolent lines...and when I jump the connector the radiator fan turns on. Why will it not turn on automatically when the car is hot??? Could the thermoswitch be wired wrong??? Anyone have an answer?
Thanks,
Dustin
Old Jan 20, 2004 | 06:39 AM
Default Re: Radiator Fan -- STUMPED (dustinsterk)
anyone?
Old Jan 20, 2004 | 07:44 AM
ttt
Old Jan 20, 2004 | 08:25 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustinsterk &raquo;</TD></TR><TR><TD CLASS="quote">... Could the thermoswitch be wired wrong??? Anyone have an answer?</TD></TR></TABLE>How do you wire a thermoswitch wrong? It's just 2 wires, all it does is close the circuit like a switch. So it's a NEW thermoswitch? I guess it's possible that it's defective.
You can check it by putting it in a pot of water. Hook it up to an ohm-meter, it should read open circuit. As you heat up the water, it will suddenly read short (0 ohms) sometime before the water boils. If you have a thermometer that reads high enough, like a meat thermometer, you can check that it closes the circuit at the proper temperature.
These days, Philly isn't very warm. You might not be able to get your cooling system hot enough to trigger this.
Old Jan 20, 2004 | 08:31 AM
Default Re: Radiator Fan -- STUMPED (JimBlake)
I will try the water trick....see if the sensor is good or defective. Thanks bro!
Old Jan 20, 2004 | 09:09 AM
JimBlake's Avatar
Just a dumb idea... Did you jump the plug with a paper clip? Maybe you spread the connectors apart so they're not real tight on the actual switch??
Old Jan 20, 2004 | 09:48 AM
used a piece of wire........but i will check that.......good idea. Thanks Again!!!
masospaghetti
Oct 21, 2014 03:35 PM
1mugencrx
Jan 6, 2014 06:07 AM
EK9JSPEC
Aug 27, 2012 09:11 PM
phoxking
Apr 10, 2011 02:05 PM
Nickg116
Mar 31, 2007 06:20 AM
