azenis in sts
Does anyone know if these tires will remain legal for sts in the following season, I found a great deal on them and need a new set of tires. ot does anyone know how much the stock 14 steels weigh?
From: boldly scornful of higher mental function, US
Nothing concrete. I am far from a source of information for the SCCA, but I heard a lot of people whining at/after Nationals about them making all other tires uncompetitive in STS. Was reading about it on sccaforums.com, Jean Kinser-Dana apparently came out with an edict to get rid of them....
Not that she is a decision maker. I am not sure when they have to announce it by, but will keep my eye on upcoming fast tracks. I would buy them, if I were running that class, and petition the hell out of the SCCA to keep them. They are wayyy affordable, and a good tire.
cool hopefully I can have them on by the next event. How do I need to prepare the tires for the first auto x? Also they wont be used very much on the street so just keep them cleen and dry between events? The winters arent to bad down here might get down below freezing at night but probably not, so the garage should be ok?
Good luck.
EC
I'm not an authority on the Falkens in particular... but I think it would be fair to say it would be beneficial to drive them a bit on the street to wear any mold-release compounds off the tread surface and get a few heat cycles in them. If anyone thinks otherwise, please post!
sorry for the O.T. post...
hmmm, Jon, so you are disapointed in those Kumhos? What were your expectations? Most people who commented about them had said they weren't the absolute stickiest, but that they were quite good for the money - which I interpreted to be better than say the P700Z that sells for a comparable price.
Just curious, as I have not had mine mounted yet, and the last time I talked to you about it, you just had them mounted
[Modified by SJR, 7:41 PM 10/2/2001]
What is a good starting point for pressure in the azenis the tires will be 195-60-14. the old 14's I had only liked 33-36 pounds in them and the 16's I run 37 f 39 r
TheIntegraGuy
Jun 19, 2002 03:55 AM
TheIntegraGuy
Jun 18, 2002 06:18 PM
Same reason the Subarus won't get booted from STS either.
