sliding timming belt on
Old Oct 1, 2001 | 08:09 PM
One8Hatch's Avatar
New User
Default sliding timming belt on
im changing my timming belt and i get it all together and now im at the point where you put the belt around the crank, tensioner, water pump, cam gear, but the damn thing doesnt want to slide on, its too short, i have the tensioner loosened, is there any tricks or tips to making this step any easier? i've been wrestling with this belt for an hour and my arms are tired. im going to go back at it tomarow after im well rested. so any helpful hints would be apreciated, thanks
Old Oct 1, 2001 | 11:26 PM
C-speed's Avatar
Default Re: sliding timming belt on (One8Hatch)
First. Are you sure its the right belt?
Second. Sometimes its easier to slightly rotate the cam sprocket so they line up better with the teeth on the belt to slide them on. Just make sure they stay aligned as you do this. Of course, you have to put the belt on the crank, tensioner, and water pump first and do the cams last.
HTH
Old Oct 2, 2001 | 12:18 AM
jeremyG2teg's Avatar
When you get to the point where your going to put it on the cams start with the exaust cam. Then get all the slack out of the belt and tensioner by pulling up on the intake cam side of the belt. That should make it a little easier for yuz.
Old Oct 2, 2001 | 12:39 PM
One8Hatch's Avatar
New User
Default Re: sliding timming belt on (jeremyG2teg)
hey thanks, and yes im postive that its the right belt, would i have to loosen the tensioner bolt to get more slack? i'll try both ideas, thanks
Kev95lx
Oct 27, 2008 04:22 AM
kornerk12
Nov 25, 2007 02:03 PM
98TypeSH
Feb 13, 2006 08:58 PM
AdamITR
Aug 28, 2002 07:11 PM
