Camber Problem!
Old Jan 19, 2004 | 08:27 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Default Camber Problem!
I've got a horrible wear problem on the insides of my front tires. It's an obvious camber issue, but the weird thing is, I don't have any lowering kits, springs/shocks or otherwise. The wear has been going on since the stock motor was on there, so it's not the B16's extra weight... So I guess my question is this: Would bad shocks and/or springs be the cause of this? I know the ones that are on the car are INSANELY old. Like at least 125-175k miles old... could this be the problem? If not, does anyone else have any ideas? Thanks guys.
Old Jan 19, 2004 | 09:30 PM
bossman032's Avatar
Default Re: Camber Problem! (VashTheStampede)
have the same problem like u.
inside wear in one off the tires.
some hit us back!!
Old Jan 19, 2004 | 09:33 PM
c jackson's Avatar
threes
Default Re: Camber Problem! (bossman032)
it could be bad shocks...it could be camber...it could be alignment. when was the last time you had your car aligned? shocks replaced?
Old Jan 19, 2004 | 09:36 PM
I had the tires changed last summer... balanced, and aligned. Same problem again... 6 month old set, 12k miles, and they're almost bald on the inside.
Old Jan 19, 2004 | 10:03 PM
CRX-RX's Avatar
Default Re: (VashTheStampede)
Doesn't sound right, if it's not alignment, and they didn't alert you to a camber situation, I would start to check for wear in the front end. Check your upper/lower ball joints, and more likely, your wheel bearings, steering rack outer/inner ends, end bushings (this woule be felt through the wheel as wandering while going straight). Bad springs/shocks won't cause a problem like you're having.
Old Jan 20, 2004 | 11:02 AM
FULL-RACE EP3's Avatar
Default Re: (CRX-RX)
it probably has nothing to do with any of that, camber, or otherwise. You probably need to get you toe-in/out adjusted.
There was a really informative topic a while back that cleared it all up. I wish I knew where it was, but anyway if more times than not camber has nothing to do with wearing the insides of the tires. Its all in a GOOD alignment, one that deals with the toe. Try a search on that.
Old Jan 20, 2004 | 01:54 PM
Overkll's Avatar
It's the toe, not the camber . I drove for 2 years with -2.5 camber (low), no problems. Hit a curb and got some toe in (forget how much) and the tire showed significant wear on the inside within 3 weeks. Just think of it as 'dragging' the inside edge of your tire everywhere you go. It's gonna where out fast. That's why a $30 alignment will save a $100 tire. I learned the hard way
HTH, Overkll
Old Jan 20, 2004 | 05:30 PM
Default Re: Camber Problem! (Overkll)
werd....
Old Jan 20, 2004 | 06:04 PM
I also use cheap-*** tires. No sense in wasting good rubber on 14 in steelies.
So I'll check it out guys... thanks!
Old Jan 20, 2004 | 08:17 PM
ThatRicerDaniel's Avatar
i had this problem once.. when i first bought a 91 si one time. it turned out that the guy who had it before hit somthing i guess and the hub was bent on the spindel. it was crazy. Its kinda hard to understand with out actually seeing it. but it can happen.
Old Jan 20, 2004 | 08:20 PM
Lo-Buck EF's Avatar
Default Re: Camber Problem! (NitrousDreamz)
if u go get an alignment, they can tell you whats out of whack (toe or camber). if its camber, then u know somehting is bent. if toe, just get it aligned
-spenc
sidoe
Suspension & Brakes
10
Mar 1, 2008 06:13 AM
integraboi1010
Nov 30, 2004 03:59 PM
90SICRX
Apr 15, 2004 10:51 AM
3 plus 1
Jan 6, 2004 01:41 AM
tFUnK
Jun 5, 2002 12:51 PM
