acura sway bars
Old Oct 1, 2001 | 07:24 PM
fuguman's Avatar
New User
Default acura sway bars
Can I use any of original acura sway bars(e.g. Type R, GSR) on my 95 integra RS. Does anyone know if the suspension is designed differently for 94-97 and 98-01 and is it different for Type R's?
Old Oct 1, 2001 | 07:59 PM
nugget8000's Avatar
New User
Default Re: acura sway bars (fuguman)
All 3g Integra rear bars are the same diameter (14mm I believe) except the type r (22mm) and therefore are interchangable, but pointless. The type r bar will go on with some slight modification to the crossmember (part thet both lower controll arms mount up to) if you don't want your crossmember to have a hole ripped in it. Go here http://www.geocities.com/bretq/ to get info on where to buy a mounting kit or instructions on hoe to make it if you choose, and also any other info for this mod. This is the kit I have and I have had no problems for about six months of enthusiastic cornering. A guy named Beak or something like that also makes what looks like a very nice mounting kit, sorry I couldn't find a link for him. HTH
Old Oct 1, 2001 | 08:12 PM
fuguman's Avatar
New User
Default Re: acura sway bars (nugget8000)
what about the front sway bar?
Old Oct 1, 2001 | 09:10 PM
SPiFF's Avatar
Same 24/14 on all non Type-R models.
Old Oct 2, 2001 | 04:55 AM
BSQ's Avatar
BSQ
You can replace your front swaybar on your '95 SE (22mm) with the front swaybar from a GS-R or a Type-R which is 24mm.
FYI, I would recommend first replacing your rear swaybar with the Type-R rear swaybar. This will greatly reduce body roll and in turn, understeer.
If you only upgrade the front swaybar you will be increasing understeer.
HTH, let me know if you have any other questions.
Liu Kang
Jul 2, 2007 07:24 PM
Crackerballer
Apr 27, 2006 07:48 AM
AMLS4dr200whp
Nov 30, 2005 11:27 AM
mickey513
Apr 4, 2002 09:08 PM
96whitels
Jan 18, 2002 10:14 AM
