92 teg radiator fit in EG?
Old Jan 19, 2004 | 06:41 PM
Beatkidd's Avatar
Default 92 teg radiator fit in EG?
i did a search and could only find 94 teg and up
will it fit?
Old Jan 20, 2004 | 05:02 PM
hadehatch's Avatar
Default Re: 92 teg radiator fit in EG? (Beatkidd)
it will not fit unless u make custom brackets on the top and bottom... it can be done, its not that hard but its not going to look pretty.. hope that helps
Old Jan 20, 2004 | 06:02 PM
Beatkidd's Avatar
Default Re: 92 teg radiator fit in EG? (hadehatch)
cool thanks for the reply
Old Jan 21, 2004 | 12:17 PM
C M S's Avatar
Buy a Del Sol dual core!
Old Jan 22, 2004 | 02:15 AM
eg6sir-s's Avatar
ived seen the 92-93 integra showa radiators in an eg chassis and it does fit. top custom brackets have to be made(im sure its not difficult). good luck.
Old Jan 22, 2004 | 05:08 AM
B18C2_sedan's Avatar
Default Re: 92 teg radiator fit in EG? (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM &raquo;</TD></TR><TR><TD CLASS="quote"> Buy a Del Sol dual core!</TD></TR></TABLE>
bolts right in
Old Jan 22, 2004 | 06:48 PM
MEANB18's Avatar
Default Re: 92 teg radiator fit in EG? (B18C2_sedan)
do you need one? I'm running a B18C5 with a bunch of extra **** and still the stock little EX radiator. Never had a problem overheating, temp doesn't even rise.
Old Jan 22, 2004 | 08:48 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadehatch &raquo;</TD></TR><TR><TD CLASS="quote">it will not fit unless u make custom brackets on the top and bottom... it can be done, its not that hard but its not going to look pretty.. hope that helps</TD></TR></TABLE>
Only bottom brackets need to be made. You can still use the stock "radiator support brackets" on the top, but need to have them in different 10mm holes on the core support. On the bottom, you need to make custom brackets but it's not that difficult, but pretty close to the alternator pulley on a H22 swap.
Old Jan 22, 2004 | 09:51 PM
Beatkidd's Avatar
Default Re: 92 teg radiator fit in EG? (Newman)
thanks guys...i was getting one for free
but i think ill just go with the del sol dual core
TRU_Luck
Dec 27, 2007 02:46 PM
B18Cej1
14
Sep 10, 2005 04:22 PM
plusONE jboy
Dec 27, 2004 11:28 PM
enigma94
Nov 5, 2004 06:17 AM
RareSI
12
May 23, 2003 01:43 PM
