question for all integra gurus.....
i have a 94 integra, my radiator is fawked, what are my other options besides getting a 94 radiator at kragens for 170+, what about civic ones? do they work and are there any cooling problems with them?
u should go to radiators.com, you can get an OEM replacement one for a lil over 100bucks shipped next day for free.... its a damn good deal check it out, and you might also wanna check radiatorbarn.com
No you can't use a Civic radiator, at least not w/o some work, because Civic radiators are only half as wide as Integra radiators. Civics have a half-wide radiator and half-wide A/C condensor, w/ a fan attached to each one. Integras use a full-width radiator, and a full-width A/C condensor in front of the radiator, and the 2 fans attach to the radiator.
c&r, KOYO, Fluidyne all good replacments if you got the $, if not check out http://www.radiatorbarn.com <-- great deals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">No you can't use a Civic radiator, at least not w/o some work, because Civic radiators are only half as wide as Integra radiators. Civics have a half-wide radiator and half-wide A/C condensor, w/ a fan attached to each one. Integras use a full-width radiator, and a full-width A/C condensor in front of the radiator, and the 2 fans attach to the radiator.</TD></TR></TABLE>
Yes you can use a civic radiator, but you will need to make some custom brackets, and get some custom hoses. It's highly recommended that you don't do this though, unless you remove your A/C. The Full-Race turbo kit requires that you run a civic radiator.
Blue-Civic-Hybrid
Jun 12, 2002 04:18 PM
