b16a2 cams vs GSR cams
Old Jan 19, 2004 | 04:04 PM
Boostage's Avatar
Default b16a2 cams vs GSR cams
I keep finding different specs for these cams.. some places list the 99si cams as more duration and slightly more lift. other sites lists the opposite..even when I search the HT arhives I find different numbers now I know the first gen b16's are inferior to gsr cams but what about the 99+? I have a set of 99's and a set of GSR cams, which do I use for turbo and which do I sell?
Old Jan 19, 2004 | 05:24 PM
Ek00fbp's Avatar
Default Re: b16a2 cams vs GSR cams (Boostage)
sell the si cams, lots of testimonials on gsr cams being very good for turbo. b16 cams are teh poo poo. But I would go sell them both and get ctr cams. vtec hits soo hard.
Old Jan 19, 2004 | 07:35 PM
Boostage's Avatar
Default Re: b16a2 cams vs GSR cams (Iloveshannon)
up
Old Jan 19, 2004 | 08:27 PM
10seceg's Avatar
werd...sell them both like Iloveshannon said and get the CTRs...you wont be disappointed.......great for turbo! (esp. w/ a nice P&P head...cough cough)
Old Jan 20, 2004 | 02:00 AM
liam821's Avatar
Default Re: (10seceg)
b16a:
Int 265 duration .412 lift
Exh 267 duration .379 lift
GSR:
Int 274 duration .423 lift
Exh 276 duration .378 lift
The trick setup is to use the GSR intake cam with a b16a exhaust cam. The idea is you want lots of lift without too much duration. People also have very good luck with GSR intake and exhaust.
Ive also heard people taking an ITR cam and having it reground to shorten the duration to GSR specs. Although i havent seen any dynos charts.
You dont want too big of a cam on the exh side because boost will go in the intake valves and right out the exhaust because both cams are open at the same time (ie valve overlap) You need the air to go into the engine and not right out the manifold.
liam
Old Jan 20, 2004 | 02:17 AM
rocket256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iloveshannon &raquo;</TD></TR><TR><TD CLASS="quote">sell the si cams, lots of testimonials on gsr cams being very good for turbo. b16 cams are teh poo poo. But I would go sell them both and get ctr cams. vtec hits soo hard.</TD></TR></TABLE>
Amen!
Guys like GSR cams because of the more duration. But if think about it CTR have more then both!!
Tuning will make all the difffernce in the world when your car is done! No matter what cams you use!
Old Jan 20, 2004 | 04:13 AM
ATS*Mark's Avatar
OG triple OG
Default Re: b16a2 cams vs GSR cams (rocket256)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket256 &raquo;</TD></TR><TR><TD CLASS="quote">
Amen!
Tuning will make all the difffernce in the world when your car is done! No matter what cams you use! </TD></TR></TABLE>
actually you want more lift less duration
Old Jan 20, 2004 | 05:12 AM
gsrhatch530's Avatar
Default Re: b16a2 cams vs GSR cams (Hella_JDM)
More lift, less duration, and more boost
Old Feb 5, 2004 | 02:42 PM
maxpsi's Avatar
Default Re: b16a2 cams vs GSR cams (gsrhatch530)
Right! Therefore, GSR cams are the best for a turbo app.?
Old Feb 5, 2004 | 04:57 PM
Dublocivic's Avatar
Default Re: b16a2 cams vs GSR cams (maxpsi)
na just get a set of good cam gears and use the ctr with the overlap dialed out.
You will make more power with higher lift.
Modified by Dublocivic at 10:13 PM 2/5/2004
spoolinvtec54
Aug 21, 2011 03:24 PM
madracer
Oct 27, 2008 04:18 AM
CBURKE
14
Dec 15, 2005 09:21 AM
pokey616
Apr 27, 2003 11:19 PM
