timing marks on oil and water pump offline at TDC
Old Jan 19, 2004 | 12:48 PM
curiousgpnoy's Avatar
Default timing marks on oil and water pump offline at TDC
aight guys heres the problem...im changing out the timing belt on my sisters 98 prelude SH and got everything TDC but the marks on oil pump and water pump where the balancer belt is are off. the oil pump looks like it has some white marks and is lined up but it looks like the stock notch is off like a milimeter...as for the water pump the notch is all the way on opposite side of its pully (12 and 6 o'clock). i did a seach and someone said that it doesnt really matter about the marks on the balancer but i want to know if it would be best to put everything back to the stock honda notches or stay with the white painted on marks?
Old Jan 19, 2004 | 02:12 PM
satan_srv's Avatar
Default Re: timing marks on oil and water pump offline at TDC (curiousgpnoy)
The crankshaft timing mark is on the FLYWHEEL, not the crank pulley
do you have a helms?
and the balancer belt you have to align it you need to use a bolt in the maintence hole etc etc.
Old Jan 19, 2004 | 04:32 PM
caz245's Avatar
Default Re: timing marks on oil and water pump offline at TDC (satan_srv)
im not sure if this pic will post since its on my pc and not on a server but here goes nothing. If it does not work email me and ill send you a pic of how the marks are suposed to be lined up.
Caz
Falloutkid90
Honda Civic (2001 - 2005)
Mar 19, 2024 07:30 AM
the soL that could
Jan 12, 2011 09:40 PM
judunty84
13
Apr 12, 2007 09:28 PM
ludewithanh22
Dec 29, 2006 03:37 PM
ahobbs
Jul 1, 2006 06:26 AM
