** New toys. NO 56k ***
Old Jan 19, 2004 | 12:37 PM
96AllMotorDC2's Avatar
Default ** New toys. NO 56k ***
This past weekend we picked up some new parts for my buddys ride. Made some nice power gains -
Type R Manifold
64mm JG ported TB
JG header, with 2 1/2 modified collector
Race pipe
STR Fuel Rail
B&M Regulator
Header was a bitch to fit in this car. had to notch out a 8 by 3 inch whole out of the core support. all was worth it though.
Old Jan 19, 2004 | 12:44 PM
P1mpSlap's Avatar
good stuff. good pics. enjoy
Old Jan 19, 2004 | 12:46 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: ** New toys. NO 56k *** (96AllMotorDC2)
looks like some good stuff there
but I would say he should take off that breather filtere and run a hose from the valve cover to the intake pipe, the engine will run and perform better overall that way.
Old Jan 19, 2004 | 02:26 PM
Default Re: ** New toys. NO 56k *** (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">looks like some good stuff there
but I would say he should take off that breather filtere and run a hose from the valve cover to the intake pipe, the engine will run and perform better overall that way.</TD></TR></TABLE>
what exactly does the hose do?
Old Jan 19, 2004 | 02:38 PM
slo2kgsr's Avatar
That hose is POV (positive crankcase venalation) air blows by the rings and builds pressure in the block. (No matter what air will get by how much depends on the age of the rings) This breather allows that pressure to be taken out and sent back through the motor. The filter doesn't provide the vac a intake does. So i suggest put it on.
Nice pics and toys
Old Jan 19, 2004 | 03:30 PM
00 FBP ItR's Avatar
How much the TB cost him?
Old Jan 19, 2004 | 03:36 PM
JDM2ndGen's Avatar
Default Re: ** New toys. NO 56k *** (00 FBP ItR)
nice how much it all cost ...and how long did the install on all the parts take ?
Old Jan 19, 2004 | 03:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">How much the TB cost him?</TD></TR></TABLE>
throttle body was $ 100 plus core exchange. to put on the manifold, tb, fule rail and regulator took about 2 hours. Took about 4 hours to put the header on. talk about frustrating. every time we would think it was going to fit. nope. same **** every time. kept hitting the core support. trail and error. 4 hours later it fit perfectly.
i would strongly recomend taking the whole core support out and notching it while its out. we learned the hard way and punched a hole through the radiator while making it fit.
oh well, nothing a little jb weld couldnt fix.
Old Jan 19, 2004 | 05:07 PM
lke2drvgsr's Avatar
how much effect did it have on power?
Old Jan 19, 2004 | 05:10 PM
Default Re: ** New toys. NO 56k *** (lke2drvgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lke2drvgsr &raquo;</TD></TR><TR><TD CLASS="quote">how much effect did it have on power? </TD></TR></TABLE>
well, pretty much before the bolt ons, the car felt pretty weak. when vtec crosses over now, you feel it, hear it, and it pulls solid. it is breathing great now. time for some skunk2 cams and call it a day.
Old Jan 19, 2004 | 05:19 PM
Fast02's Avatar
nice ride-great pics!!
Old Jan 19, 2004 | 05:27 PM
lke2drvgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96AllMotorDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
well, pretty much before the bolt ons, the car felt pretty weak. when vtec crosses over now, you feel it, hear it, and it pulls solid. it is breathing great now. time for some skunk2 cams and call it a day.</TD></TR></TABLE>
correct me if i'm wrong, but you shouldn't feel a spike in power when vtec engages... vtec is just a way of making it easier for the engine to breathe at higher rpm's so it can make hp up high to make up for the lack of torque due to the small 4 cyl engine... but back to my point, it should be a constant acceleration, not a jump at vtec... if it is, then the car definitely needs to be tuned... and definitely don't just call it a day after the skunk2 cams are installed cuz you wont gain any power without tuning nice mods tho!
Old Jan 19, 2004 | 05:33 PM
DIY's Avatar
DIY
damn cali emissions... that header would look sooo much prettier without the heatshield
great pics.. looks great
keep it up
Old Jan 19, 2004 | 05:42 PM
systemfan444's Avatar
Default Re: ** New toys. NO 56k *** (DIY)
nothing beats the look od brand new parts.....very clean
Old Jan 19, 2004 | 07:33 PM
H22A EG6's Avatar
Default Re: ** New toys. NO 56k *** (systemfan444)
did you dyno? i am intersted in the gains
Old Jan 19, 2004 | 07:54 PM
JDM2ndGen's Avatar
Default Re: ** New toys. NO 56k *** (H22A EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 &raquo;</TD></TR><TR><TD CLASS="quote">did you dyno? i am intersted in the gains</TD></TR></TABLE>i would liekto know as well ...
Old Jan 19, 2004 | 07:59 PM
Community Builder
whoa I didn't notice the heat shield... is that new header underneath the factory heat shield, and if so how was it secured in place? If I get a header I would love to keep the factory heat shield because I want to keep my engine bay looking as stock as possible.
Old Jan 19, 2004 | 08:03 PM
JDM2ndGen's Avatar
i dont think there is a pick of the header actually on the motor ...i could be wrong though ...
Old Jan 19, 2004 | 11:01 PM
DigitalPunk's Avatar
Default Re: ** New toys. NO 56k *** (JDM2ndGen)
Now you should raise the rev limiter, shift that bitch at 8500 rpms, and drop that ET like its hott
Old Jan 20, 2004 | 12:19 AM
correct me if i'm wrong, but you shouldn't feel a spike in power when vtec engages... vtec is just a way of making it easier for the engine to breathe at higher rpm's so it can make hp up high to make up for the lack of torque due to the small 4 cyl engine... but back to my point, it should be a constant acceleration, not a jump at vtec... if it is, then the car definitely needs to be tuned... and definitely don't just call it a day after the skunk2 cams are installed cuz you wont gain any power without tuning nice mods tho! </TD></TR></TABLE>
well actually there is a pretty big jump in the power when vtec crosses over. i guess because it is a generic chip in the ecu and it is not for his exact setup.
sorry, pictures are a little misleading. the header is not installed in the photos. it got dark outside and couldnt take pics with the header installed. but if you guys want to see final pics, i will post tommarrow.
Old Jan 20, 2004 | 12:25 AM
00 FBP ItR's Avatar
throttle body was $ 100 plus core exchange. </TD></TR></TABLE>
wow... 120 w/ core from me.
Old Jan 20, 2004 | 06:45 AM
ebelp's Avatar
I would suggest a VAFC also if you go with the Skunk2 cams...
Old Jan 20, 2004 | 06:50 AM
mist sITR's Avatar
i really lie that fuil rail
Old Jan 20, 2004 | 07:12 AM
B18C2_sedan's Avatar
nice parts. I can not wait to see how much hp you gained.
Old Jan 20, 2004 | 08:49 AM
lke2drvgsr's Avatar
then tune it and you should be able to make a bit more low end power
