How many O2 sensors does a 93 VTEC have?
Old Jan 19, 2004 | 07:39 AM
PhatboyNYC's Avatar
Default How many O2 sensors does a 93 VTEC have?
I did a search and couldn't come up with anything. I have a 93 VTEC and the check engine light recently came on. I checked the CEL code and it's a 41 which indicates an O2 sensor problem if I'm not mistaken. I've been looking to find a replacement O2 sensor and checked with several shops. Surprisingly, I've been getting different responses as to what was needed.
Some shops told me that I need two O2 sensors, one before and one after the cat. Another shop told me I needed 4?!?!
When I checked the Hondaautomotiveparts site, it lists only 1 O2 sensor before the cat. So which is it? Do I just need 1 or more? Thanks in advance.
Old Jan 19, 2004 | 07:55 AM
jdm22vtec's Avatar
Default Re: How many O2 sensors does a 93 VTEC have? (PhAtBoY Si)
there should only be one for the H22 right before the cat.
Usually B series and other motors have 2. One by the header and one by the cat. Thats probably why you're getting different answers from people who dont know the differences between the motors.
Hope that helps. Can anyone else confirm this.
Old Jan 19, 2004 | 07:57 AM
AndyD's Avatar
Default Re: How many O2 sensors does a 93 VTEC have? (jdm22vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm22vtec &raquo;</TD></TR><TR><TD CLASS="quote">there should only be one right before the cat.</TD></TR></TABLE>
There should only be one that is located on the downpipe fo the header.
Old Jan 19, 2004 | 10:16 AM
Honda Sport's Avatar
Default Re: How many O2 sensors does a 93 VTEC have? (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
There should only be one that is located on the downpipe fo the header.</TD></TR></TABLE>
that is correct.
Old Jan 19, 2004 | 11:10 AM
see_our_vtec's Avatar
which is just before the cat
Old Jan 19, 2004 | 12:11 PM
mattmw88's Avatar
Default Re: How many O2 sensors does a 93 VTEC have? (see_our_vtec)
Does anyone know the real difference between code 41 and code 1? i know one is for the heated O2... What could the problem be, the sensor or wiring to the sensor? This is a problem that I have always had ever since the motor swap about a 1.5 yrs ago and have never been able to conquer... Thanks for the input.
Old Jan 19, 2004 | 01:45 PM
pentaq's Avatar
Default Re: How many O2 sensors does a 93 VTEC have? (mattmw88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattmw88 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the real difference between code 41 and code 1? i know one is for the heated O2... </TD></TR></TABLE>
41 is for the sensor heater. And there could be two reasons: sensor itself or wiring. There is a whole procedure to solve this. It's in helms though.
Old Jan 19, 2004 | 02:42 PM
luder94-ChrisA's Avatar
FYI - OBD I ludes (92-95) have one oxygen sensor, OBDII Hondas generally have two sensors...
Old Jan 19, 2004 | 03:36 PM
thehondaguru's Avatar
Default Re: How many O2 sensors does a 93 VTEC have? (luder94si)
Like said before you only have one right before tha cat.... if you have an cat
JonBrown
Jul 2, 2010 07:57 PM
b18cKoupe
Honda Civic (2006 - 2015)
Feb 5, 2009 11:04 PM
pr0gress
Oct 21, 2005 01:01 PM
aaronblake9898
Feb 13, 2004 03:55 PM
smooz EK
12
Nov 12, 2003 10:07 AM
