How are GSR cams better for boost than Si'??
99 si's have a longer intake duration. and a tiny bit more lift. I know the longer duration increase overlap a tiny bit. but theoretically these 99 cams should flow more air and yeild more power per RPM.
ALL listed at @ 1mm!
Integra GS-R
Int-230 dur. / 10.6mm lift
Exh-227 dur. / 9.4mm lift
Civic Si '99 Spec
Int-240 dur. / 10.7mm lift
Modified by Boostage at 4:16 PM 1/19/2004
Integra GS-R
Civic Si '99 Spec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">99 si's have a longer intake duration. and a tiny bit more lift. I know the longer duration increase overlap a tiny bit. but theoretically these 99 cams should flow more air and yeild more power per RPM.
Integra GS-R
Civic Si '99 Spec
Modified by Boostage at 4:16 PM 1/19/2004</TD></TR></TABLE>
dude i donno where you got your info..but its wrong.
b16a:
Int 265 duration .412 lift
Exh 267 duration .379 lift
GSR:
Int 274 duration .423 lift
Exh 276 duration .378 lift
liam
ps https://honda-tech.com/zerothread?id=739146
Integra GS-R
Civic Si '99 Spec
b16a:
GSR:
liam
Aren't there a couple different "b16a" cam profiles? Could the b16a2 from the Si have a slightly more aggresive profile?
*edit* nevermind, doesn't this look right actually?
Following cam measured with 0mm of lift:
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
From the ClubSi cam guide. Lots of specs. Dunno if they are 100%.
Civic Si(1999 Spec)
Integra GS-R
jdmcivicb16a2sc61
13
May 23, 2006 04:55 AM
