diffs between h22 and h23 intake manifold
Old Jan 19, 2004 | 05:49 AM
jweller's Avatar
Default diffs between h22 and h23 intake manifold
I did a search. I read a bunch of stuff but all I could find out was that they are different, and you can't swap them. can anyone tell me what the differences between them are? I know about the butterflys, but otherwise, I'm pretty ignorant. specifically, I'm concerned about where they meet up with the head. so basically, head stud location, runner size, and runner location. If one of them is definately better from the factory, which one?
possibly going onto a F series motor.
Old Jan 19, 2004 | 06:10 AM
H22Si's Avatar
Default Re: diffs between h22 and h23 intake manifold (jweller)
honestly both manifolds don't perform very well, but they work. the h22 manifold would deffinately be the better performer between the two. i believe the only difference between the two is the runner crosssection. where the h22 is larger.
i'll take a closer look at both when i go by the shop tonight.
Old Jan 21, 2004 | 10:15 AM
jweller's Avatar
anybody else?
Old Jan 21, 2004 | 10:58 AM
prelittlelude's Avatar
as far as what people have said in the past is that from the butterflys up is the same, even the throttle body, and the only difference is the bottom half that bolts to the head.
Old Jan 21, 2004 | 11:03 AM
uNbrokeN's Avatar
its all the same throttle body... no need to change or anything, caues a HUGE hype over it
Old Jan 21, 2004 | 12:00 PM
PirateMcFred's Avatar
the flange is different between the h22 and the h23. the EGR port is different and I think that coolant goes through the h23 manifold near the EGR port. bolt pattern is differnt too. HTH
the Pirate
Old Jan 22, 2004 | 10:48 AM
jweller's Avatar
Default Re: (PirateMcFred)
yeah thanks that was exactly the kind of stuff I was looking for
I guess I'll just end up buying both IM gaskets, since both of them will have to be modified.
Old Jan 22, 2004 | 12:30 PM
satan_srv's Avatar
Default Re: (jweller)
Bolt Pattern, Flange AND port spacing are different
I don't think you can do it. Besides there are ones on ebay right noe for cheap!
Chavy340
Sep 22, 2025 11:04 PM
blurry454
Jun 24, 2009 10:11 AM
2kdrift
Sep 10, 2007 05:36 AM
1994PreludeSi
Jan 7, 2007 07:24 AM
ludaboy93
Jan 24, 2006 07:52 AM
