cylinder head and block swap interchangability question
this may have already been asked but i tried searching to no avail.
I have a 93 integra LS with the 1.8 non-vtec dohc b18a? motor, which has about 160,000 miles on it and it runs great never leaks or burns any oil the oil is clean. i take really good care of this car. all i have is an intake (long type with k&n), cat back exhaust, and poly motor mounts.
will a 2.0 or another block work with my 1.8 head and give it higher compression and more power? i realize i would have to change a lot of things but i was just wondering if anyone has done this. im thinkin ill get a 2.0 at a junk yard.. get it machined, balance everything, take my head off, rebuild and port polish it, and put it on the other motor, port the intake or get a better one, get bigger fuel injectors (would i have to?), get a ignition box and coil, nology hot wires, +4 spark plugs.. and run it off 91 or 93 octane.. any suggestions and what all should be changed to do this right? (if possible) ty -Thomas
what 2.0L are u thinking of getting? the only 2.0L honda motors are out of the early 90's prelude and the S2000. i dont think either of those are the ones you had in mind. what you could do is, keep your block and put a GS-R (vtec) head on it.
edit: oops i forgot about the shitty CRV motor, that's 2.0L too. maybe thats what you had in mind. either way, that wouldnt be worth the money. you need vtec to be fast.
sepulchral
Jun 9, 2006 06:50 AM
frenchy
Jun 2, 2004 01:10 PM
