How difficult is hood pin installation?
Old Oct 1, 2001 | 03:14 PM
Jon7's Avatar
Default How difficult is hood pin installation?
I just ordered a set of sparco hood pins to for my CF hood. The hood does not sit too well and I don't trust it w/o hood pins. Can someone explain the process involved in getting the pins in. I'd be up for paying someone to do it if there is a small margin for error in terms of screwing the hood up. Thanx.
Old Oct 1, 2001 | 03:18 PM
Tommy_Gunns's Avatar
Default Re: How difficult is hood pin installation? (Jon7)
Put the pins in the rad support first. Put some grease or vaseline on the end of the pins, close the hood gently and the vaseline should mark where you should drill the hole into your hood.
Hoped that helped....it is much more difficult to install locking hood pins like I have....lining these up is a bitch!
PS - If your afraid to do it, get a professional to install it for you, don't take any chances.
[Modified by Tommy_Gunns, 6:30 PM 10/1/2001]
Old Oct 1, 2001 | 10:48 PM
Rhetoric's Avatar
It isn't that difficult if you got some drilling skills. You can use the pre existing holes in the radiator support to mount the stems. Make sure when you find where you are going to drill that you tape the spots up with duct tape as a reinforcment. Take your time as well, if your carbon fiber hood cracks(ive seen a few shops that have messed up) I dont believe you can fix it like a fiberglass hood. Good luck.
Old Oct 2, 2001 | 06:20 AM
backlash's Avatar
The best advice I can give is to take your time. Drill the holes smaller and gradually enlarge them. I have the blue Sparco hoodpins. They bend very easy, so don't tug and pull on them because they will bend. They look dope and have served their purpose on my car very well
Old Oct 2, 2001 | 06:43 AM
Jon7's Avatar
Default Re: How difficult is hood pin installation? (backlash)
Should the drilling be done while the hood is on the car to better see how to align the pins?
Devo94ac
Mar 9, 2006 05:47 AM
93HatchCali
86
Nov 25, 2003 08:33 AM
Uneekpinoysk8er
12
Apr 23, 2003 10:32 PM
JSpecwest
Nov 17, 2001 10:40 PM
