maintenace light on...how do i turn off/reset on a EP?
its nite time rite now so i cant see anything under the dash...just as the topic ses...
youwould think they would have a small dome light under the steering column for such things as this or atleast have it on the dead pedal.. hmmm.. i think i just came up on a selling product...!!!!!!!
The exact procedure is in your manual, but I think you put the key in the
ignition, turn it to accessory, and hold down the odometer button until it
goes off. That may be slightly off, though.
actually you put the key in the ignition and put it on the on position make shure you do not start the car. just to the point where all the indicators light up. press down on the reset button for the odometer for about 10 to 20 seconds and it will reset. when you do disconect the terminals thas when you want to reset your ECU and not the maintanence light
