Replacing lifters/valve adjustments
Old Jan 18, 2004 | 04:34 PM
carl_aka_carlos's Avatar
Default Valve adjustments
Ok, I have a 94 Integra RS, and I need to replace the lifters and do a valve adjustment.
Can anyone who has done this tell me what kind of job I'm in for? I'm pilfering all the parts from a spare head I have sitting around.
I just ordered the Honda service manual, but other than that I've not too much experience with this sort of thing.
Modified by carl_aka_carlos at 6:29 PM 1/18/2004
Old Jan 18, 2004 | 05:00 PM
B20vtec86crx's Avatar
Default Re: Replacing lifters/valve adjustments (carl_aka_carlos)
there are no lifter in your non vtec motor ..you adjust valves with your cams in and on tdc ...using feeler guage between rocker and cam lobe..good luck
Old Jan 18, 2004 | 05:29 PM
Default Re: Replacing lifters/valve adjustments (B20vtec86crx)
so i just took a look at my spare head....
now where is it that I make the adjustment? on the nut the attaches on the end of the rocker arm? i'll get a pic if you don't know what I'm trying to describe
also, where am I going to get a feeling gauge?
Old Jan 18, 2004 | 06:30 PM
turboxsi's Avatar
feeler gauge can be purchased from any auto parts store i.e. Autozone, sears, olympic auto parts etc....
Old Jan 18, 2004 | 07:46 PM
Default Re: Replacing lifters/valve adjustments (turboxsi)
that's what i understand. for some reason i was under the impression that you needed a specific one or something. like i said, this will be my first serious work on the engine besides changing oil or any other simple jobs
Old Jan 20, 2004 | 06:23 PM
you adjust the valve by loosening the nut on the of rocker (lock )and adjust clearance with flat head screw driver or vaLve adjusting tool and lock the nut back up when you have the correct clearance
dakwag
Jul 24, 2012 07:17 AM
Big red89
Dec 18, 2007 10:44 AM
zach1288
45
Apr 17, 2007 06:40 PM
riceball777
Feb 2, 2004 09:45 PM
Mugen Dom
10
Jul 29, 2002 02:20 AM
