i need help with fuel on turbo crx
Old Jan 18, 2004 | 04:08 PM
91glassycrx's Avatar
Default i need help with fuel on turbo crx
i'm getting a 16g turbo from a friend and i'm running 5 psi and i get a walbro 255 in tank fuel pump and a fmu ( boost dependent fuel preesure regulator) will that work and can i keep my stock injectors on obnly 5 psi let me know thanks
Old Jan 18, 2004 | 04:32 PM
red cx's Avatar
Default Re: i need help with fuel on turbo crx (91glassycrx)
at only five psi you will be fine.
Old Jan 18, 2004 | 04:53 PM
1.8turbolsvtec's Avatar
you will be good at 5 psi
Old Jan 18, 2004 | 04:55 PM
Suleman963's Avatar
your good for 5, get bigger if you go higher then 7
Old Jan 18, 2004 | 05:01 PM
nsxmatt's Avatar
If your running a FMU it's better to run a inline over a intank pump. A intank can't provide the pressure needed for a FMU like a inline provides. At 5psi you might get by with it but it's better to be safe.
Old Jan 18, 2004 | 05:31 PM
88crxvtec's Avatar
if you have the intank, you could do a VAFC and get some DSM injectors. Since you have a CRX you don't need the resistor box since you already have it. Run the AFC hack, a little bit better than the FMU route
kHoA DoGG
May 14, 2003 11:29 PM
TurbothisLS
Sep 22, 2002 07:22 AM
DsMWookie
Sep 12, 2002 08:22 AM
KLN
Jun 3, 2002 11:02 AM
fast[R]
Apr 27, 2002 06:09 AM
