Input bearing spun
Old Jan 18, 2004 | 03:56 PM
Average Al's Avatar
Default Input bearing spun
I have a tranny that i took apart.
When i took it apart alot of metal shavening came out and piece of bearing droped out. I look at the inout bearing and it spun in it (seat?).
is it possible to fix the seat like press a new on in and out??
Is this tranny garbage now? Would the gear still be good to make an hybrid tranny?
Old Jan 18, 2004 | 04:38 PM
acy76's Avatar
Default Re: Input bearing spun (Average Al)
I can't really tell from the picture how badly the case is damaged, but as long as you can still get a nice, square and tight interference fit with a new bearing I don't see why you couldn't fix it.
Old Jan 20, 2004 | 04:32 PM
Average Al's Avatar
by look at the casing doesn't look like i can get a nice fit with a new bearing
any sugestion on what to do?
is the casing replable? like pressed in or something
Old Jan 20, 2004 | 05:06 PM
Mohudsolo's Avatar
Default Re: (Average Al)
It's hard to tell, but it looks like the outer race of the bearing may still be in the case. If it is, you can just pull the remains out and see what is left. I would be surprised if the outer part of the bearing did spin since is is a ball bearing not a plain bearing. Can you set the camera on macro and put it inside the case for a better closeup shot?
Old Jan 20, 2004 | 08:55 PM
Average Al's Avatar
there a hole in the seat yhou romove the nut to push the bearing out and there a hole in the treads
Modified by Average Al at 6:19 AM 1/21/2004
Modified by Average Al at 7:17 AM 1/21/2004
Old Jan 20, 2004 | 09:27 PM
Average Al's Avatar
The seat looks fine but behind it looks rough its all chewed up.
Would the tranny be fine if the bear explodes? Where can i look for wear.
It still spin but wasn't smooth. Never ran before by be.
Modified by Average Al at 7:18 AM 1/21/2004
Old Jan 21, 2004 | 04:18 PM
Average Al's Avatar
up is this tranny any good anymore?
Old Jan 30, 2004 | 10:04 PM
Average Al's Avatar
IS THIS SEAT any good anymore
Old Jan 31, 2004 | 04:46 PM
acy76's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Average Al &raquo;</TD></TR><TR><TD CLASS="quote">by look at the casing doesn't look like i can get a nice fit with a new bearing
is the casing replable? like pressed in or something</TD></TR></TABLE>
If you can't get a proper fit with a new bearing, I think you will have to replace the case half.
EFinawesomeman
Apr 30, 2009 06:04 PM
mgags7
Sep 28, 2005 06:31 AM
crexer
Aug 28, 2005 05:00 PM
T-Mo
Apr 19, 2004 05:23 AM
