B16A swap into 93 Integra using a P30 ECU throwing Code 13
As the topic says, I swapped a jdm b16a into my 93 Integra and using a jdm P30 ecu. Both are obd-1, but after the swap, the car is throwing a Code 13.
I checked helms and saw its a baro sensor issue, did a search on this site and others, but I'm pretty confused now.
Does the JDM ecu require an external baro sensor, and the 93 Integra's stock ecu have an internal ? Or is it reversed ?
Either way, any help that can be provided would be greatly appreciated.
Only other ecu I have is from my b18a1, and given that its a USDM, and was in the car before, it should work fine. The main question is whether the Baro sensor is internal on OBD-1s, and if so, is it different for JDM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HHogan »</TD></TR><TR><TD CLASS="quote">Only other ecu I have is from my b18a1, and given that its a USDM, and was in the car before, it should work fine. The main question is whether the Baro sensor is internal on OBD-1s, and if so, is it different for JDM.</TD></TR></TABLE>
Yes according to my helms the baro. sensor is internal to the ECU.
Don't know if that's the case on all OBD1 ECU's or even if it's true on JDM ECU's but it is true of least the P61, and whatever the non VTEC integra and civic OBD1 ECU's are.
And the helms also says the ECU bases it's settings on the baro sensor. ( I don't know what the ramifications are of that, though)
Did you try resetting it? Or opening it?
