Grinding when Transmission Fluid Gets too Hot?
I was at the track last weekend and on my second run I couldn't shift down to second at high speeds without grinding. I was not rev matching or heel toeing, which I suspect this would eliminate the grinding issue. However, since I still need to practice at that, it is not currently an option.
So here's my question, were the gears grinding because the transmission fluid got so hot that it wasn't letting the synchros spin at the right speed to allow a smooth down shift? If this is true, then would changing to a heavier transmission fluid or somehow cooling the transmission better help with the grinding?
And if the above is true; is there a transmission cooler available for the R? Or could I make something?
Thanks in advance!
Thanks in advance!
hmm, so this only happens on your later runs? Cause the syncro shouldnt let you into 2nd if you are going too fast - that's what a syncro is supposed to do.
Maybe someone else can help, but all I can say is don't force it - if it doesnt go in easily, it doesnt go in.
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
also try changing your clutch fluid. RS was having some grinding problems and some other shifting problems and that solved it for him.. well except now his 3rd gear sync is screwed up..
The Collin
Aug 22, 2008 08:00 PM
civic_speed99
Jan 20, 2005 06:39 PM
