new problem
Ok, I have a new problem wiht my buddy's b16. After sitting idle or driving inthe city the oil light will come on then go off. Then a little bit later it will come on again then the engine with start over heating? Anyone have an idea what might be causing that? I'm at a loss. oil seems to be pumping fine and there are no air bubbles in the cooling system. I am at a loss.
how do you know if oil is pumping? do you have a gauge? check oil levels yet? never ever drive with oil pressure light on....you might be able to drive from point a to point b without problems but you are doing serious damage to engine's bearings. the will seize up and your motor is toast
why do people do this, their oil light comes on and they figure it'll fix itself or its not big deal. Sorta like when your engine starts knocking, for heaven's sake why keep driving it?
Anyway, yea check your pressure, pump, even drop your pan who knows whats in there making it act weird
well I know there is pressure because I have checked. I don't hav ehte numbers on my right now. The car is at my buddy's house. That is why I posted this query on here. I know what he oil light is for but I am not getting any reading that there is a problem with the oil pumpo at all.
xlasianizelx
May 1, 2008 07:42 AM
