LSD Questions
Old Jan 17, 2004 | 11:49 PM
bossman032's Avatar
Default LSD Questions
Hello guys,
I have a question..
Hmm I have an LSD tranny when ever I turn on like enter freeway on ramp the tires start to squeek only when I turn or enter the onramp freeway or try to exit a curb even a slow speeds..
Is that the LSD kicking in?? Cause my OLD ys1 gsr tranny didn't do that its the sound that you try to take a corner to fast that sound the tires squeek but I am doing it a very low speeds.
is that the LSD kicking in??
Old Jan 18, 2004 | 12:09 AM
MaxSterling's Avatar
Default Re: LSD Questions (bossman032)
lsd is mechanical, it always present. its not vtec where its computer controlled. honda LSD is gear base and you are suck with it
Old Jan 18, 2004 | 06:30 AM
rapid_roy's Avatar
What kind of tires do you have? What pressure are they at? What suspension bits do you have on your car?
If you are squeeling your tires on turn in, check the nut behind the wheel. You may want to think about your driving style and hether or not you are turning in to quickly, you might be jerking the wheel which might feel good to you but it's the best way.
As for pulling out....slow down?
Cheers,
Sean
Old Jan 18, 2004 | 07:03 AM
Kendall's Avatar
Default Re: LSD Questions (MaxSterling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">lsd is mechanical, it always present. its not vtec where its computer controlled. honda LSD is gear base and you are suck with it</TD></TR></TABLE>
This is correct, a Honda LSD can't "kick in." Nor can any other LSD on the market. Subaru and Mitsubishi make Active Center Differentials, they're adjustable, but again are always present.
Old Jan 18, 2004 | 08:15 AM
doublejz's Avatar
Default Re: LSD Questions (Kendall)
could be: alignment, camber if your lowered, tire pressure, slow down
Old Jan 18, 2004 | 10:15 AM
bossman032's Avatar
Default Re: LSD Questions (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">could be: alignment, camber if your lowered, tire pressure, slow down </TD></TR></TABLE>
yes I have a STD EF9 have alignment and camber issues its stock height running at about 22ps on some 95GSR Rims in the front and 13s at the back.
Old Jan 20, 2004 | 12:36 PM
rapid_roy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">
22psi? That's about 10psi to low, you might want to up that and see how it behaves.
Cheers,
Sean
Old Jan 20, 2004 | 04:24 PM
Sliced Beard's Avatar
Default Re: LSD Questions (rapid_roy)
also if you hear squealing in the back it is most likely your steelies
the stock size tires tend to not grip very well
Old Jan 30, 2004 | 09:45 PM
LX4CYL's Avatar
heh, I remember when my I put my stock tires back on my accord, and they were underflated (after sitting in the garage for a year), they would squeal almost the entire time on the way to the gas station (to get air)
Old Jan 31, 2004 | 07:21 AM
blacksihatch's Avatar
damn
i dont know about everybody else out there but damn
i would think that all suspension issues should be dealt with first before you start with the performance upgrades im suprised you didnt say you springs were cut down.
i curious to see f you have any pics of this beast?
93gsrhatch_1
Transmission & Drivetrain
Feb 23, 2012 10:50 PM
MrMug3n
Apr 21, 2008 05:04 PM
CaliforniaHighwayPatrol
47
Jul 25, 2005 08:12 AM
damnraz
Jun 16, 2005 08:02 PM
