Help install: Apexi VAFC 2
Old Jan 17, 2004 | 08:47 PM
blackntegra's Avatar
Default trouble with VAFC2 on my ITR
yesterday i installed a VAFC2 on my R. (jdm 96 spec)
i have connected all the wires except for the.....
VTM signal
VTC cam signal
DTC signal
(because i cant find them)
i understand that i dont need the VTC signal, cos that is for I-vtec engines.
but what about the VTM and DTC? i notice my car jerks like its stalling after vafc2...
can any one tell me which wire they will be?
i cant find it on the apex-i site.
and can anyone tell me what the "settings" should be on a R?
for example, number of sensors in and out?
Old Jan 18, 2004 | 12:07 AM
Doctor CorteZ's Avatar
Default Re: trouble with VAFC2 on my ITR (blackntegra)
did you receive a manual with your VAFCII ?
Old Jan 18, 2004 | 05:29 AM
Toda Built's Avatar
I think you can download the online version of the install instrucitons on apexi's web site
good luck
Old Jan 18, 2004 | 12:22 PM
i cant seem to find the install instructions on the site. i have looked already. they only have the users manual, which only tells you how to operate it.
could anyone post the ECU diagram for the ITR? i cant get hold of a Helms manual...
Old Jan 18, 2004 | 12:30 PM
Misfit's Avatar
Default Re: (blackntegra)
http://www.bseries.net/html/garage/vafc.php
there you go. i searched google for like 5 seconds and found this one.
Old Jan 18, 2004 | 03:45 PM
Hairy Gorilla's Avatar
Default Re: (MISFIT)
man I just ran into the same problems as you when putting this on my GSR. The VTC is for i-vtec like you said so just leave it. By DTC did you mean TDC? If so that is also for i-vtec. Check out my thread for additional help w/ the VTM signal wire....
https://honda-tech.com/zerothread?id=704930
And if yoru lazy, let me clear this up for you. Use teh diagram found here, http://www.apexi-usa.com/produ...e.pdf
BTW, i dont know what year you are, but I am pretty sure they screwed that up. If you are 96-99 integra, use WH-2, 00-01 uses WH-3 diagram. Understand??
Edit, your 96, use the WH-2 diagram. Worked for me...
Old Jan 18, 2004 | 05:40 PM
Default Re: (Tim Maryak)
yeah thanks for that link. i have already seen it before though...
the VTM signal wire, i cant find on my ecu...
my ecu doesnt have a wire on that position
i just hope i dont need it
could you tell me how many in/out sensors you have, in your settings?
thanks
Old Jan 18, 2004 | 10:23 PM
Hmmm...I am guessing the JDM thing is screwing everything up.
I'll have to get back to you tomorrow on that one...
nicopod
Jun 20, 2003 12:43 AM
4drhybrid
Mar 28, 2003 12:46 PM
NVMYSi
Sep 11, 2002 10:54 AM
jdmrealm
Oct 25, 2001 09:17 AM
4doorH22
Oct 2, 2001 08:10 PM
