wasup with the SMOKE COMING OUT ?? and OIL? where is it coming from??
Old Jan 17, 2004 | 08:36 PM
crxturboh22's Avatar
Default wasup with the SMOKE COMING OUT ?? and OIL? where is it coming from??
sup yall its me again.. I got some oil leak.. somewhere!1 NO clue where its coming from but everytime I park my car I get a stain of oil on floor.! its leaking from some where!! not the axle.. las time i looked it was coming from the metal plate that goes behind the tranny!! know waht i'm talking about??? between the block and the tranny!!!! its not tranny oil.!!! my MOTOR oil is hella LOW!! and its not from the oil pan either!! help me out!!. I looked under the car but i have no clue1! its coming from the side of the tranny!!
Old Jan 17, 2004 | 08:46 PM
Default Re: wasup with the SMOKE COMING OUT ?? and OIL? where is it coming from?? (jz)
But do you have any CLUE where it could be coming from!! do U know if there's any Presure form the OIL Return line.. ??? cuz mine is mount on the block .. right next to the pulley and its not tight. so i'm leeking a lil bit.. could I be leaking while i'm driving.. ??? bad!! if there's presure.. i'm talking about the OIL return line.. from the turbo to the oil pan!!! could that be IT???????????????????????????????????????????????? ???????????????????????????????
Old Jan 17, 2004 | 09:01 PM
JonGP4's Avatar
Default Re: wasup with the SMOKE COMING OUT ?? and OIL? where is it coming from?? (crxturboh22)
it could be anything.. if ur saying it coming between the block and trany its most likely the rear main seal.. time to drop the trany.. it could very well be the oil return.. its not under much pressure.. but mine leaked even with a clamp
Old Jan 17, 2004 | 09:09 PM
Default Re: wasup with the SMOKE COMING OUT ?? and OIL? where is it coming from?? (JonGP4)
Yo GP4.. hold it right there! lol.. so it could be the rear main seal??? is that behind the Flywheel ???? any pics of anycar that i could see!! ? or u can explain better.. * u're on the right track.. keep it up!!!!
Thanks.
Old Jan 17, 2004 | 09:15 PM
I was just thinking... u know!! Every 1 here are like my own personal mechanic!! most of the time I get everythign solved here! hehe.. its true.. its good to have some 1 to help! .
drastikmeasurez
Jul 22, 2005 04:59 PM
NaVamous
Mar 8, 2005 02:05 AM
cyrock
Oct 4, 2004 12:55 PM
Campee
16
May 20, 2003 05:33 PM
