OBD conversion?
Old Jan 17, 2004 | 07:55 PM
darksol2005's Avatar
Default OBD conversion?
i'm planin on swappin a d16z6 into an 88-91 crx. before i start it though, i wanna know if i'll have to do any obd conversion stuff? i don't exactly know ANYTHING about that, so if someone could help me out that'd be kick ***
Old Jan 17, 2004 | 08:48 PM
4crx4me's Avatar
Default Re: OBD conversion? (darksol2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darksol2005 &raquo;</TD></TR><TR><TD CLASS="quote">i'm planin on swappin a d16z6 into an 88-91 crx. before i start it though, i wanna know if i'll have to do any obd conversion stuff? i don't exactly know ANYTHING about that, so if someone could help me out that'd be kick ***</TD></TR></TABLE>
Yes, and it depends on which CRX you start with though, as to how much work you'll have to do.
If you use ANY engine newer than 1991 , which the Z6 is, you'll have to consider OBD conversion stuff.
Old Jan 17, 2004 | 09:00 PM
sloweredcivic's Avatar
actually you don't have to consider obd conversions. but, i seriously recomend one i have a 90 dx hatch with the multi point conversion wich you'll need if you don't drive a hf or si. if you have a 90-91 crx civic you can use the z6 clutch and flywheel (wich is better because more friction area. i did a obd1 conversion and am running my z6 with a p28 ecu. good luck any other questions im me.
Old Jan 17, 2004 | 09:07 PM
4crx4me's Avatar
Default Re: (sloweredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic &raquo;</TD></TR><TR><TD CLASS="quote">actually you don't have to consider obd conversions.</TD></TR></TABLE>
If he wants to run a Z6 in a CRX, how do you figure the above?
He has NO CHOICE. It's an OBD 1 SOHC VTEC. (or maybe OBD2?)
What are the other options?
Old Jan 17, 2004 | 09:10 PM
SOHCEK-Turbo's Avatar
Default Re: (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">
What are the other options?</TD></TR></TABLE>
Yes he does he can stay non obd with a pm6 and si dizzy and run a vtec controller.
Old Jan 17, 2004 | 09:21 PM
4crx4me's Avatar
Default Re: (SOHCV-TechRider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCV-TechRider &raquo;</TD></TR><TR><TD CLASS="quote">
Yes he does he can stay non obd with a pm6 and si dizzy and run a vtec controller.</TD></TR></TABLE>
THAT is an OBD conversion, my friend.!!
Albeit a reverse one, but an OBD conversion, nonetheless. (and counter-productive)
Seeing as the ENGINE is a different OBD than the car is.
And don't forget to add that he has to convert the OBD1 injectors on the engine to OBD0 injectors, as well.
Old Jan 17, 2004 | 09:29 PM
you don't have to change the injectors you just have rewire them by taking out the injector resistor and solder all of the wires together
Old Jan 17, 2004 | 09:35 PM
And don't forget to add that he has to convert the OBD1 injectors on the engine to OBD0 injectors, as well.</TD></TR></TABLE>
Wells since you put it that you are right it is an obd conversion but he doesnt have to convert the car to obd1. Which he might be asking about. Staying obd0 isnt counter productive I know a few heads with obd0 setup on their Z6 and their dynos are still just as good as obd1 conv. I did conv. to obd1 dough. And I recommend it if you want Hondata tunning or any kind of good tunning.
Modified by SOHCV-TechRider at 6:53 AM 1/18/2004
Old Jan 18, 2004 | 09:14 AM
alright, thanks guys. i'm startin to understand a lil more. could you help me out and gimme some info on exactly what needs to be done for a d16 into a 91 crx?
Old Jan 18, 2004 | 09:27 AM
WONG FRIED RICE's Avatar
that depends on you. you can choose to do or not to do. it all depends on whether or not you want to use obd1 wiring or not. Either way you are going to have to use a p28 ecu, unless you are using some kind of management, so ur probably going to use a jumper harness of some sort. If you use your OBD 0 wiring, ur going to need a OBD 0 dizzy as well. So basically u have a few options.
If you have more questions feel free to PM me or email me @ jdmb16acrx@yahoo.com. I have the d16z6/y8 in my crx, and made a jumper harness myself too!
Old Jan 18, 2004 | 09:29 AM
4crx4me's Avatar
Default Re: (darksol2005)
Which CRX? DX or Si or HF?
Which D16? And what year car did it come from?
What comes WITH the new engine? Distributor? ECU? etc.etc?
silly80
Dec 21, 2007 11:01 PM
cb1400f
Jul 13, 2007 06:04 PM
kusakari_boy
Dec 8, 2006 08:49 PM
psyko
Jan 24, 2006 04:05 AM
fitzov
Jun 5, 2004 03:28 PM
