please help, car won't start and wife is mad at me!
Old Jan 17, 2004 | 07:30 PM
keng's Avatar
Default please help, car won't start and wife is mad at me!
Hey guys, I need your help. I have a 94 civic v-tec. The car was running just fine not problem except me o2 sensor. So I pulled the car in to replace the o2 sensor with a bosh universal one and I replace the cap and rotor. Now the car will not star. There is no spark. I put the orignal cap and rotor back on still won't start. I checked to codes,reset the computer, nothing. Thre is no check engine light either. could the o2 sensor stop the car from running? what can I do or check to see why I am not geting any spark. whould having my firing order wrong stp the car from starting. thatnks guys
Old Jan 17, 2004 | 07:34 PM
clm's Avatar
clm
Default Re: please help, car won't start and wife is mad at me! (keng)
What happens when you try to start it? Sounds like an ignition issue if it happened after messing with it.
Old Jan 17, 2004 | 07:49 PM
97civicdx's Avatar
Did u bend the little spring thing just under the cap? Take a close look at it, its inside the tower part of the dist when it connects to the cap.
Old Jan 17, 2004 | 08:24 PM
keng's Avatar
clm- the car cranks strong, but just won't turn over, she wants too, but it is not getting spark or firing. what else can I check.
97civicdx- Yes I did bend the spring under the cap. I streched it out a tiny bit to make better contact with the tip inside of the rotor. I belive it is supposed to make contact. I could be wrong. what other good advice do you guys have, you guys are awesome.
Old Jan 17, 2004 | 08:30 PM
Team 4R's Avatar
Default Re: (keng)
so it is cranking over but just won't light up...? hmmmm........ last time i had this problem a ground wire had come undone..... i would say make sure the ecu is plugged in, but it sounds like you didn't even come close to that...... did you make sure your rotor is properly aligned with the rest of your timing?
Old Jan 17, 2004 | 08:31 PM
sshaikh01's Avatar
take the dist. cap back and get it exchanged it should be free.
also check to make sure you have the wires lined up propperly.
and NO O2 sensor won't stop your car from starting, its something to do with the wires, or the dist. cap.
Old Jan 17, 2004 | 08:33 PM
2lua's Avatar
Default Re: (keng)
did unplug and replug wire one at a time or all at one? you could cross your plug wire
Old Jan 17, 2004 | 08:34 PM
civicnightmare's Avatar
Default Re: please help, car won't start and wife is mad at me! (sshaikh01)
holmes
zensoku207's Avatar
Def ignition problem......
check to make sure the plug wires are all the way on the distributor and in the right order. If those are mixed up, the car won't start.
Old Jan 17, 2004 | 08:35 PM
dude check the ground on the starter my ecu wouldnt turn on and that was my problem it tried to crank but just wasnt firing i did that and bam she cranked right up
Old Jan 17, 2004 | 08:39 PM
keng's Avatar
team4r- I never messed with the ecu, I checked and double checked all connectors. The rotor is slotted, it will only go on and off one way.
I replaced the new cap with my orignal and no spark.
zlua- I did unplug my wires, I think i connectd them right on the cap, but I do not have a example or diagrame to verify it. does anyone have an example of the correct way the wires should be on the cap? you guys are awesome thanks for you help!
Old Jan 17, 2004 | 08:49 PM
2lua's Avatar
Default Re: (keng)
let see... you look at your cap where the plugs plug in facing you and it had 3 screws the screw by itself at the round part of the cap the one on the left is number 1 the one on the right is 2 the top right is 4 and top left is 3...
Old Jan 17, 2004 | 09:01 PM
keng's Avatar
clm- how you doing man,
ok so on the cap the plug on the very bottom is #1, right next to it is #2, TOP right is #4 and TOP left is #3 is ths correct?
Old Jan 17, 2004 | 09:05 PM
cxSHOE's Avatar
Default Re: (keng)
could also be your ignitor or coil.... this happened to me just putting a new distributor cap on... my coil was bad, got a new one worked, then the ignitor went bad the next day .. all is good now.... tricky i must say...
Old Jan 17, 2004 | 09:13 PM
keng's Avatar
how can i check the ignitor and coil?
Old Jan 17, 2004 | 10:16 PM
JDMlyfestyle's Avatar
check them with a Ohm meter to make sure there getting current. you should have 13-20 ohms if not then u got a bad coil
Old Jan 18, 2004 | 12:00 AM
keng's Avatar
anyone else have any advice?
What wires do i check to see if teh coil or igniter is good?
Old Jan 18, 2004 | 08:39 AM
Team 4R's Avatar
Default Re: (keng)
just to confirm, the plug wires look like:
3 4
1 2
i had mine crossed one time, but the motor still started..... bad idle, terrible vibration, and occasional backfiring.... but, it still started. so, that's not your problem.
i'm looking at my honda troubleshooter under "engine rotates but will not start". here's the list of possible problems starting with the most likely. hope this helps.
1. fuel tank empty
2. battery discharged.
3. battery connection loose or bad
4. leaking injectors, faulty fuel pump/system
5. fuel not reaching fuel rail
6. ignition components damp/damaged
7. faulty spark plugs
8. broken/loose/disconnected wiring in starter circuit
9. loose distributor
10. faulty ignition coil
Old Jan 18, 2004 | 08:46 AM
SLeePeR012's Avatar
Default Re: (zensoku207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zensoku207 &raquo;</TD></TR><TR><TD CLASS="quote">Def ignition problem......
check to make sure the plug wires are all the way on the distributor and in the right order. If those are mixed up, the car won't start.</TD></TR></TABLE>
Yea recheck that.
Old Jan 18, 2004 | 08:55 AM
clm's Avatar
clm
Default Re: (SLeePeR012)
Have you checked your fuses?
If you have a quick connection I can set up an FTP for the EG Helms manual (about 90 mb) or go the local library or parts store and get the Haynes.
Old Jan 18, 2004 | 02:13 PM
keng's Avatar
Team4R
well it was # 10. My coil tooka dump. But help me out here, I never touched anything on the coil. I replaced the cap and rotor, then she would'nt start. It falls it the realm of unexplained automotive grimliens. As soon as i replaced the coil she fired right up.
TO ALL OF YOU:
YOU GUYS ARE AWESOME I CAN'T THANK YOU GUYS ENOUGH FOR ALL YOUR HELP AND ASSISTANCEA. IT IS BECAUSE OF YOU GUYS THAT I GOT MY WIFE'S CAR BACK ON THE ROAD. I AM IN HAWAII IF YOU GUYS NEED OR WANT ANYTHING THAT I CAN HELP YOU OUT WITH JUST LET ME KNOW. WHAT MAKE A GREAT MESSAGE BOARD IS PEOPLE REALLY WANTING TO HELP EACH OTHER OUT THANKS GUYS, KEN
Old Jan 18, 2004 | 02:41 PM
GTlvr82's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">check them with a Ohm meter to make sure there getting current. you should have 13-20 ohms if not then u got a bad coil</TD></TR></TABLE>
It says in the Honda Factory manual that it should be between something like 16-20....I just messed with this crap the other day. I replaced cap and rotor and the CYP sensor, ignitor, AND the coil went bad....replaced all but CYP and it runs almost perfect.
Old Jan 18, 2004 | 07:43 PM
Team 4R's Avatar
Default Re: (keng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keng &raquo;</TD></TR><TR><TD CLASS="quote">As soon as i replaced the coil she fired right up.</TD></TR></TABLE>
it's always nice when stuff just works........
Dtmk69
Jan 5, 2016 10:27 AM
tedo2007
13
Dec 4, 2009 09:58 AM
egtony
11
Jul 20, 2009 09:59 AM
egtony
Jul 19, 2009 10:18 AM
