half shafts
Old Jan 17, 2004 | 03:07 PM
sabertooth's Avatar
Default half shafts
any usdm half shaft the same as the zc half shaft.
Modified by sabertooth at 1:13 AM 1/18/2004
Old Jan 17, 2004 | 04:13 PM
sabertooth's Avatar
bump damn i need somethin
Old Jan 17, 2004 | 04:32 PM
coos's Avatar
Default Re: (sabertooth)
yep
Old Jan 17, 2004 | 04:55 PM
sabertooth's Avatar
is there and equivilent usdm zc half shaft?
Old Jan 17, 2004 | 06:07 PM
sabertooth's Avatar
i been wacking the inner cv hub with pickle forks and screw drivers n hammers. i need a different idea how to get it off its a zc by the way
Old Jan 17, 2004 | 07:27 PM
sabertooth's Avatar
Default Re: half shafts (sabertooth)
bump
Old Jan 17, 2004 | 07:51 PM
JonGP4's Avatar
so ur just trying to get your axles out of the half shaft?.. if so you need a BIG *** pry bar and hammer.. if that doesn't work take it to someone with a lift and a 4ft pry bar, thats the only way to get it out
Old Jan 17, 2004 | 08:20 PM
sabertooth's Avatar
ya i used a 12" first and broke it then a 18 and it didnt work so i went to 24 n it still didnt work
Old Jan 17, 2004 | 08:42 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sabertooth &raquo;</TD></TR><TR><TD CLASS="quote">is there and equivilent usdm zc half shaft?</TD></TR></TABLE>
No.
No USDM ZC. No USDM ZC halftshafts.
Old Jan 17, 2004 | 08:54 PM
sabertooth's Avatar
i i got the answer to that now im tryin to figure out how to remove axle cup from int. shaft in case u neglected to read the entire post
attentionwhore
21
May 13, 2008 08:05 PM
SIXTY
Apr 13, 2006 08:25 AM
s2kkk
Aug 17, 2004 06:00 PM
4g4drb17
16
May 27, 2004 01:15 AM
