filling tranny fluid
Old Jan 17, 2004 | 03:06 PM
fast+forward's Avatar
Default filling tranny fluid
can i take off the tranny vent cap & fill the tranny fluid through the vent? the VSS is in a really hard to reach place and the fill plug nut is not cooperating..thanks for any help
Old Jan 17, 2004 | 05:20 PM
PhatOptimo's Avatar
Default Re: filling tranny fluid (breakaway)
The vent cap is not a good spot. I use the fill plug. Work at getting the fill plug off 17mm. Jack it up so you can get some leverage on it. Its not too bad when you get the plug out.
Old Jan 17, 2004 | 06:14 PM
onePOINTsix's Avatar
Default Re: filling tranny fluid (PhatOptimo)
what i do is get a big funnel and fill through the reverse swtich and remove the fill plug, fill it untill it comes out the fill hole and your all set
Old Jan 17, 2004 | 06:50 PM
mmuller's Avatar
Mad Scientist
Default Re: filling tranny fluid (Sideout)
use the vss, is actually pretty simple if you have a long funnel and the intake is out of the way
Old Jan 17, 2004 | 06:55 PM
ALLMOTOR18's Avatar
Default Re: filling tranny fluid (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">use the vss, is actually pretty simple if you have a long funnel and the intake is out of the way</TD></TR></TABLE>
Thats how I do it...
Old Jan 17, 2004 | 07:36 PM
Default Re: filling tranny fluid (ALLMOTOR18)
alright...gonna work on gettin through the reverse sensor..so the vent is an absolute no no? its starting to look tempting...
Old Jan 17, 2004 | 08:12 PM
quik1's Avatar
Don't use the vent use the proper fill spot so that you know that its at the right level. If you don't have the right funnel its time to invest into one there not expensive. Over filling can be worse than under filling.
Old Jan 18, 2004 | 12:48 AM
FULLTHROTTLE's Avatar
Default Re: filling tranny fluid (quik1)
Overfilling the tranny by a few ouces is not going to kill it. It will just cavitate the oil a little. You can use the vent tube if you have a little patience. If the fill plug is rounded off it may be a good alternative. What tranny do you have? If its a B series it will take 2.7 qts to fill. hope this helps. I hate stripped fill plugs.
Old Jan 18, 2004 | 08:12 AM
doublejz's Avatar
Default Re: filling tranny fluid (FULLTHROTTLE)
2.7? every b16 i worked on took 2 qts maybe like 2.2
Old Jan 18, 2004 | 01:03 PM
Default Re: filling tranny fluid (doublejz)
I just filled mine yesterday, and 2 qts wont even come close. I used a little bit over 2.5 so if you are filling it blindly 2.7 is a safe amount. there is room for too much oil and not enough too.
Old Jan 18, 2004 | 06:14 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">2.7? every b16 i worked on took 2 qts maybe like 2.2</TD></TR></TABLE>
i agree with him, i never had a tranny(hydro or cable) take over two quarts! i'll have to check the helms, on the oil capacity of the tranny!
Old Jan 18, 2004 | 09:15 PM
Default Re: filling tranny fluid (smokey2.0)
My Honda service manual says 2.0 US qts. for D series and 2.4qt. for DOHC.
Old Jan 19, 2004 | 02:06 AM
HYBRID_H@TCH's Avatar
another thing..make sure you fill it up with the car sitting leval..every time I have the front end jacked up I can only get 1.5 in it so maybe thats why some only get 2.0 or 2.2 in it..
a funnel and a 3 foot heater hose with a tube hanging out to fit in the vss hole is the easyest way I have found..
Old Jan 19, 2004 | 11:01 AM
Cyphear's Avatar
I made a beer bong type thing outta a cheap funnel and a few feet of clear plastic hose from home depot. just undo the fill plug, drop the hose down from the top, then go underneath and put it in the fill hole, then your ready to pour. ...just like a beer bong... ahh beer...
Old Jan 19, 2004 | 02:03 PM
smokey2.0's Avatar
Default Re: filling tranny fluid (99Hybrid_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">another thing..make sure you fill it up with the car sitting leval..every time I have the front end jacked up I can only get 1.5 in it so maybe thats why some only get 2.0 or 2.2 in it..
a funnel and a 3 foot heater hose with a tube hanging out to fit in the vss hole is the easyest way I have found..</TD></TR></TABLE>
i too have noticed this, but it's hard to have the car in a neutral position and be able to reach the fill hole. i'll be getting a funnel, some clear hose from home depot, and buying 1QT containers to fill the tranny through the vss hole
northkai3
26
Sep 29, 2013 11:53 AM
Andrew14
21
Jun 28, 2010 01:12 PM
lsegcoupe
Oct 25, 2006 03:59 AM
JDMfrontedLS
17
Jun 23, 2006 11:08 AM
92-LS-Civic
Dec 2, 2004 08:39 AM
