Rough, low idle.........
Old Jan 17, 2004 | 02:38 PM
cdk's Avatar
cdk
Default Rough, low idle.........
ok, i have a 97 lx d16 (auto), i can adjust the idle set screw, which works fine, after the car is warm when in it is gear like at a stop light, the car seems to be shakey, not that bad but just bugs me, no matter how high i turn up the idle set, when in gear it adjusts to lower (shakier) speed, any ideas? I have cleaned the IAC and it seems to be operating fine, is there anything else that controls the idle speed at park or in gear, are they different? Thanks.
Old Jan 17, 2004 | 02:39 PM
cdk's Avatar
cdk
Default Re: Rough, low idle......... (cdk)
also replaced the cap, plugs and cleaned it the tb about 8K ago.
Old Jan 17, 2004 | 02:50 PM
Discosteak's Avatar
did u try the plug wires? that was my prob
Old Jan 17, 2004 | 02:55 PM
Daniel's Avatar
When was the last time you adjusted the valves? If it was recently, the valve lash may be too tight. I had the same thing happen to my '97 D16Y8 where at stoplights the battery light would flicker because the engine wanted to stall out. And at times it would stall out (but luckily fire up again right away). It wasn't a constant problem; some days it would idle alright but other days it would idle VERY low and do as I described above. It turns out my valve lash was too tight. (This started happening right after I had my valves adjusted.) Now everything is good.
Old Jan 17, 2004 | 03:20 PM
sleepyhamsterlx's Avatar
Default Re: Rough, low idle......... (Daniel)
mine is doing the same thing. Suck don't it. Ive changed everything out and nothing seems to be helping out. i want to know how to fix it too.
Old Jan 17, 2004 | 03:23 PM
igo4bmx's Avatar
Default Re: Rough, low idle......... (sleepyhamsterlx)
hey man
i have anauto d16also... and i had that problem a while back..
i tried the cap, distributor, new plugs, fuel injector cleaner,
nothign worked until i "reset" the ECU
Old Jan 18, 2004 | 07:42 AM
StreetwizeRacin2's Avatar
sounds like symptoms im having with my GSR, is it bogging out too?
Old Jan 18, 2004 | 09:50 AM
cdk's Avatar
cdk
Default Re: (StreetwizeRacin2)
no, no bog down, still plenty of power. Same thing here, some days ok, others shitty. It never gets to stalling, just goes from shakey to fine, for the ecu reset did you pull the backup fuse of disconnect the battery? Ill look at the wires also, they are like pretty new also i think, i did them over the summer but ill check for leakage, corosion and tightness. Thanks!
Old Jan 20, 2004 | 09:44 AM
cdk's Avatar
cdk
Default Re: (cdk)
okay just outta curiosity i pulled my plugs finally (caused im retarded and kept trying the wrong size socket) and they look like this, been in for 10K (look normal a little brown, not that much electrode wear, AND a thin ring of black carbon around the rim on the plug, not thick not on the white eletrode just on the metal, pretty baked on also, doenst come off easily, I know alot of carbon anit normal, is this normal with civics? and no carbon from the tailpipe and I still get good gas mileage. Any opinions normal or not? Thanks.
Old Jan 20, 2004 | 09:50 AM
976's Avatar
976
New User
Default Re: (cdk)
Intake manifold - Use carbon build up cleaner
Throttle body - do the same
Clean air filter
Clean IAVC
Change oil
Replace PCV valve
Index your spark plugs
Fuel injector cleaner
Use higher octane
Fuel filter
Did you just replace cap, or rotor as well?
Modified by 976 at 11:15 AM 1/20/2004
Old Jan 21, 2004 | 11:43 AM
cdk's Avatar
cdk
Default Re: (976)
where is the pcv located?
Old Jan 21, 2004 | 07:23 PM
cdk's Avatar
cdk
Default Re: (cdk)
ok, i completed all the tasks recomended, what could cause it to be runnin slighty rich or not igniting all the way?
ddubtoille
Aug 13, 2008 02:39 PM
MLevinson
Jun 22, 2008 06:35 PM
94acurals
Aug 21, 2007 02:47 PM
jaycapz
Sep 1, 2004 02:43 PM
raene
Nov 7, 2002 08:21 PM
