o2 sensor max voltage
Old Jan 17, 2004 | 02:34 PM
david90's Avatar
Default o2 sensor max voltage
what should be the max voltage that comes out of the o2 sensor wire on hondas?
Old Jan 17, 2004 | 03:23 PM
non-VTEC's Avatar
Default Re: o2 sensor max voltage (david90)
1 volt max
Old Jan 17, 2004 | 10:03 PM
david90's Avatar
Default Re: o2 sensor max voltage (non-VTEC)
i have a primary and a secondary o2 sensor, which one should my a/f gauge be connected to?
Old Jan 17, 2004 | 10:06 PM
david90's Avatar
Mine doesn't seem to get pass .9v. whats wrong?
Old Jan 21, 2004 | 01:34 PM
non-VTEC's Avatar
Default Re: (david90)
your A/F guage should be connected to the primary o2 sensor signal output wire.
.9v is rich........why would you want it more than that?
at wide open throttle you want it to be around .850 to .900 to get the most power on a mostly stock engine.......
astroxtc
Dec 13, 2006 12:57 PM
Jared
Oct 13, 2002 10:38 AM
LsTurbo91
Oct 8, 2001 09:20 PM
