How to change a thermostat?
Old Jan 17, 2004 | 10:57 AM
93jdmr's Avatar
Default How to change thermostat?
I wanted to know how to change the thermostat on my itr? Do i need a new gasket or does it come with it?
Old Jan 17, 2004 | 11:40 AM
Dropspeed's Avatar
Default Re: How to change thermostat? (93jdmr)
Best thing for you to do is purchase a Helms manual. It will answer at least 95% of your maintenance questions. It is easy to do.
Mattj
Old Jan 17, 2004 | 01:00 PM
nightrider's Avatar
make sure you have the right tools or else you'll strip the nut. i am speaking from experience and i have yet to get that damn thermostat out because the nut is stripped.
Old Jan 17, 2004 | 01:32 PM
StyleTEG's Avatar
Default Re: How to change thermostat? (nightrider)
Its easier to get to if you remove the starter.
http://www.team-integra.net/se...D=222
Here is an article detailing the rest.
Old Jan 17, 2004 | 06:19 PM
TeamNextGenChris's Avatar
Default Re: How to change thermostat? (Dropspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">Best thing for you to do is purchase a Helms manual. It will answer at least 95% of your maintenance questions. It is easy to do.
Mattj</TD></TR></TABLE>
thank you!if everybody weren't too cheap to buy a shop manual,half the questions on this board wouldn't even need to be posted.
chris
Old Jan 17, 2004 | 11:54 PM
Rhetoric's Avatar
Default Re: How to change thermostat? (TeamNextGenChris)
I just replaced mine. I used honda bond to seal it. Its two bolts to remove. The one in the rear takes some manuevering to get to.
Old Jan 18, 2004 | 12:03 AM
b19coupe's Avatar
Default Re: How to change thermostat? (Rhetoric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhetoric &raquo;</TD></TR><TR><TD CLASS="quote">I just replaced mine. I used honda bond to seal it. Its two bolts to remove. The one in the rear takes some manuevering to get to.</TD></TR></TABLE>
1/4" drive 10mm swivel socket
Old Jan 18, 2004 | 12:06 AM
Toda Built's Avatar
Its very easy... follow the lower radiator hose all the back behind the block. Where the radiator hose ends that is where you thermostat is. Remove the two bolts and possibly the ground wire for the thremo switch. Remove old thermostat and place new one in its place (remember to use new O-ring). Place cover over thermostat and put the two bolts back in place (don't forget the ground wire). Refill you coolant and your done.
Old Jan 18, 2004 | 12:24 AM
Brian Samoa's Avatar
New User
Default Re: How to change thermostat? (Toda Built)
Thanks for the info. guys.
Syndacate
20
Aug 9, 2006 06:09 PM
quik sol
28
Jan 3, 2004 10:34 PM
wm5holla
20
Oct 9, 2003 03:24 PM
inzaneN1
May 12, 2003 06:38 PM
King_j
May 6, 2003 09:58 AM
