URGENT WIRING ISSUES
Old Jan 17, 2004 | 10:25 AM
meams's Avatar
Default URGENT WIRING ISSUES
I'm swapping out my D16y5 (SOHC VTEC-E) for a D16y8 (SOHC VTEC) and i wanted to konw if i could use my D16y5 wiring harness for the y8....I have another wiring harness but it doesnt plug into either of hte P2P (y8) ECUs right...only 2/3 of the plugs on the harness fit the ECU and the 3rd plug is for the gauge cluster...so there's an empty socket on the ECU (there's 2 empty sockets, one doesnt have pins thougH).
Help asap...my car is 1/2 way in my garage and we're awaiting a reply from this thread.
Thanks in advance
-Tom.
Old Jan 17, 2004 | 10:50 AM
meams's Avatar
Default Re: URGENT WIRING ISSUES (meams)
bump bump we're all sitting in the garage and we're doing busy work waiting for a reply...
Old Jan 17, 2004 | 12:13 PM
meams's Avatar
someone has got to know the answer to this...please help i need the info by tomrrow
Old Jan 17, 2004 | 12:52 PM
b20_ed's Avatar
what year is the d16y5 out of? what year is it going into? What year is the motor??
Old Jan 17, 2004 | 01:13 PM
meams's Avatar
Default Re: URGENT WIRING ISSUES (b20_EK)
sorry in all my rushing i forgot all that...umm its a 98y5 and the guy i got the y8 from told me its from a 00'. from wath i could tell the harnesses are almost identical..but its hard to compare when there's all those similar plugs.
Old Jan 17, 2004 | 05:42 PM
PHiZ's Avatar
Ues the engine harness that came with the car, run the wires for vtec, and vtec oil pressure sensor from the sensors to the ecu. Use a 96-98 civic ex ecu.
-PHiZ
Old Jan 17, 2004 | 06:17 PM
b20_ed's Avatar
Default Re: URGENT WIRING ISSUES (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Ues the engine harness that came with the car, run the wires for vtec, and vtec oil pressure sensor from the sensors to the ecu. Use a 96-98 civic ex ecu.
-PHiZ</TD></TR></TABLE>
BAM! problem solved.
Old Jan 17, 2004 | 08:16 PM
meams's Avatar
how the hell do i run the wires for VTEC into the ECU? dont' they have to be pre-wired with the clips that are at the end of the harness....p.s. i am not mechanically inclinded..my friend is doing alll thsi for me...could he handle it?
Old Jan 17, 2004 | 08:34 PM
PHiZ's Avatar
And apparently your friend is not qualified to do it, becuase you are here.
http://www.hondaswap.com/swap/viewer.php?id=58
Will tell you which pins VTS and VTM are.
You will need the sensor plugs (sounds like you already have a usable harness to steal them from), and you will basically need something like this to go into the back of the chassis harness ecu plugs to connect to the ecu:
http://www.crimethink.org/obd2....html
The chassis harness ecu plugs are in the foreground.
-PHiZ
Old Jan 18, 2004 | 05:41 AM
meams's Avatar
PHiZ thanks so much, do you know where i can find a pinout chart of the P2P ECU? i did a search but dindt find any on here.
pwnstar
Jan 18, 2010 07:57 PM
AGENT 99
Sep 10, 2006 09:36 AM
ChaosUnbound
Sep 23, 2005 06:24 PM
project civic
May 23, 2005 08:32 AM
thenick
15
May 20, 2003 12:53 PM
