What ecu to use for uberdata obd1 for h22a4?
Old Jan 17, 2004 | 08:22 AM
gdrum's Avatar
Default What ecu to use for uberdata obd1 for h22a4?
I was told p72 then also p28 then even a cheap p08 and mod it. Whats cheapest yet will still work. obd1 for h22a4
Old Jan 17, 2004 | 10:19 AM
gdrum's Avatar
Default Re: What ecu to use for uberdata obd1 for h22a4? (gdrum)
anyone?
Old Jan 18, 2004 | 06:56 AM
gdrum's Avatar
Bump for ideas???
Old Jan 18, 2004 | 08:49 AM
NoLipRacen's Avatar
well if you are using the stock IM and you want to retain the IAB's then i suggest a p72. i know that when im going to run hondata i will do so on the p72.
Old Jan 20, 2004 | 12:44 PM
R-Toyz.com's Avatar
A P28 can be tuned to run an H22 hard even if it doesnt have IAB control. You have to get the timing and fuelling correctly keeping in mind that the IABs are open all the time. We've done this for a client before and he's very happy with it.
This is cheaper than running a P72 ECU. If you do decide to run a P72, make sure you retune the fuel maps since the you're running a bigger motor.
Old Jan 20, 2004 | 07:48 PM
gdrum's Avatar
Default Re: (rtzcom)
i was going to get a p06 and chip it...vtec all of that...then uberdata it...just for the fact u can get p06s for almost free and chipping it if u know how to do it is free so thats my idea..
Old Jan 21, 2004 | 02:44 AM
R-Toyz.com's Avatar
Default Re: (gdrum)
The P06 has to be converted to run VTEC. You need more than just the chip to that.
Old Jan 21, 2004 | 07:57 AM
gdrum's Avatar
yes i know, but its really quite simple, so if i converted it to vtec and then made it chipable......itd work just as fine correct?
Old Jan 24, 2004 | 11:23 AM
R-Toyz.com's Avatar
Default Re: (gdrum)
Yup
B18Cyko5
May 31, 2012 11:45 AM
cyrock
Jun 25, 2006 01:29 AM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
blackie
Jul 10, 2005 03:38 PM
