How to clean calipers?
How do you clean old calipers, that are rust all over? I brushed the rust down, but how should I make it near the cylinders? I need to remove the rust there, but I can't do it with brush.
Little rust is also in the groove for the dust rubber on the pistons, how to remove this? The pistons deeper are rust-free.
The rust is like this:
Go to your local DIY and get a 'wire cup' drill bit and also a 'wire stem' drill bit, these just literally go onto your drill and will bring the rust of with a little effort without damaging your calipers, but watch the rubbers.
Use a dremel with those tiny wire brush attatchments you can get right in, then wash it thoroughly with brake cleaner fluid. Around the rubbers carefully use a screwdriver wrapped in a rag and go around the rubbers once the fluid has had a chance to soften the deposits. Once cleaned up give em a spray of rust preventer to stop em rusting up again.
Whats up with people and saying I want this done by a professional, every single time I have had something done to my car other than myself, I have had worse results rather than if I did it myself. I don't believe in what everyone calls "professionals" the people at auto shops are not professionals and do not have the ability to know as much about your car as you do. Think about it, you only have to know how to work on 1 car, mechanics and other people work on tons of different cars, granted they have a little more experience, if you just read some stuff you should have a greater knowledge of your own car than they do.... I think one of the only exceptions to this is availability of tools, but you really don't need any rare tools unless your doing some serious work, and even then you can rent or barrow those... Just thought i'd get that one off my back
oh, and by the way, you could try penetrating oil also, that is made to decompose rust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 »</TD></TR><TR><TD CLASS="quote">Whats up with people and saying I want this done by a professional, every single time I have had something done to my car other than myself, I have had worse results rather than if I did it myself. I don't believe in what everyone calls "professionals" the people at auto shops are not professionals and do not have the ability to know as much about your car as you do. Think about it, you only have to know how to work on 1 car, mechanics and other people work on tons of different cars, granted they have a little more experience, if you just read some stuff you should have a greater knowledge of your own car than they do.... I think one of the only exceptions to this is availability of tools, but you really don't need any rare tools unless your doing some serious work, and even then you can rent or barrow those... Just thought i'd get that one off my back
oh, and by the way, you could try penetrating oil also, that is made to decompose rust.</TD></TR></TABLE>
Agreed. People dont take enough pride in their work; "just as long as the pay comes through every month..." etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT »</TD></TR><TR><TD CLASS="quote">
Agreed. People dont take enough pride in their work; "just as long as the pay comes through every month..." etc</TD></TR></TABLE>
Agreed too....some things I can't do myself due to space and or tools, but what I would suggest is either a wire brush, steel wool or a dremel tool..... what was that about olive oil how or does this work???
Agreed. People dont take enough pride in their work; "just as long as the pay comes through every month..." etc</TD></TR></TABLE>Agreed too....some things I can't do myself due to space and or tools, but what I would suggest is either a wire brush, steel wool or a dremel tool..... what was that about olive oil how or does this work???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekkynikality »</TD></TR><TR><TD CLASS="quote">somewhat OT, but how do you clean paint off the caliper?</TD></TR></TABLE>
Aircraft paint remover or brake parts cleaner will work as well.
As for getting rid of the rust, use a wire tip drill bit as someone stated before. It's just that easy. If you plan on painting them, use a high temp paint.
Fuster_Cluck
Mar 13, 2003 08:05 AM
