check out this fully built block
Old Jan 17, 2004 | 01:58 AM
Prelude91siT's Avatar
Default CHECK OUT THIS FULLY BUILT BLOCK IS IT WORTH 2700
is this worth 2700?
84mm bore
Golden Eagle Mfg. "Goldzilla" sleeves ( holds 60 psi of boost
Eagle rods
ACL engine bearings
Arias Pistons
Bored and honed
Line bored
Sized rods
Balanced crank and rotating assembly
Polished and chamfered oil hole crank
Blueprinted and assembled bottom end
sce copper head gasket
[/img]
Modified by Prelude91siT at 12:00 PM 1/17/2004
Old Jan 17, 2004 | 02:01 AM
BoOsTeD_eK's Avatar
Default Re: check out this fully built block (Prelude91siT)
It isnt worth it...the block is a B20Z...which means the owner paid more for the original block than he would of if he would of just went with a B18B block. If he was going to sleeve it..he should of just went with the B18B sleeved and bored to 84mm..just my 2 pennies.
Old Jan 17, 2004 | 02:08 AM
EpDarks's Avatar
Default Re: check out this fully built block (BoOsTeD_eK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoOsTeD_eK &raquo;</TD></TR><TR><TD CLASS="quote">It isnt worth it...the block is a B20Z...which means the owner paid more for the original block than he would of if he would of just went with a B18B block. If he was going to sleeve it..he should of just went with the B18B sleeved and bored to 84mm..just my 2 pennies.</TD></TR></TABLE>
Looks like a B20A to me... look again.
Old Jan 17, 2004 | 02:10 AM
LOOK CLOSER ITS A JDM B20A WICH IS THE FIRST GEN B-SERIES THAT CAME OUT IN THE 88-91 PRELUDES
Old Jan 17, 2004 | 04:29 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT &raquo;</TD></TR><TR><TD CLASS="quote">LOOK CLOSER ITS A JDM B20A WICH IS THE FIRST GEN B-SERIES THAT CAME OUT IN THE 88-91 PRELUDES</TD></TR></TABLE>
What's the rod/stroke ratio of that block?
Old Jan 17, 2004 | 05:04 AM
Frozen E's Avatar
H-T White Ops
wow, those are HUGE slugs in there compared to the tiny B16's.
I like it. Worth $2700 though, I dunno.
Old Jan 17, 2004 | 06:52 AM
Kelly.'s Avatar
I've quit using this account
its an old skool prelude motor.
what are planning on puttint it in?
i dont think its wirth it unless you are putting it in the same kinda type of car it originally came outta.
Old Jan 17, 2004 | 06:59 AM
THE GUY WHO IS SELLING IT SAID HE PAID AROUND 3200 FROM GE TO HAVE IT THE WAY IT IS NOW. THE R/S I BELIEVE IS 1.49 AND YES I PLAN ON PUTTING IT IN MY CAR WHICH IS A 91 PRELUDE 2.0SI
Modified by Prelude91siT at 8:58 PM 1/17/2004
Old Jan 17, 2004 | 07:14 AM
vod's Avatar
vod
dude your caps lock is stuck on.
get a new keyboard.
Old Jan 17, 2004 | 07:23 AM
quickergixxer's Avatar
Default Re: (Prelude91siT)
oh boy i had a 90 2.0 si back in the day, can you rev those? my friend is paying 2800 for a b18 darton/cp/crower all assembled
make him a offer se how low he will go
Old Jan 17, 2004 | 07:44 AM
vtekthis's Avatar
didnt those old school preludes come also with a 2.2 liter?
Old Jan 17, 2004 | 08:01 AM
Default Re: (vtekthis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis &raquo;</TD></TR><TR><TD CLASS="quote">didnt those old school preludes come also with a 2.2 liter?</TD></TR></TABLE>
92's came with 2.3 but thats a different body
Old Jan 17, 2004 | 09:01 AM
they came with a 2.0 and a 2.1. but i guess it could be worth it then since your boy bad 2800 for is fully built block. just let me know what u think and is it worth 2700 does it seem like a deal a lil
Old Jan 17, 2004 | 09:07 AM
TURBO4drTypeR's Avatar
more like 2000 tops...2700 is a ripp!!!homie hookup or not!!!
anyways goodluck in whatever you decide
Old Jan 17, 2004 | 11:33 AM
93LSivic's Avatar
Default Re: (TURBO4drTypeR)
First off, that isnt a sleeved block. Second off you are not supposed to use a copper head gasket with a copper o-ringed block. Third off, that has got to be the worst motor honda ever made with the shitty rod ratio that is has. Forth off, I wouldn/t have paid that much for a normal B20 built.
Old Jan 17, 2004 | 12:02 PM
y do u say it isnt sleeved. everything that is mentioned above is what has been done from golden eagle. and yeah we do have one of the shittiest r/s ratio but my car stock is still faster than any civic stock except for an si which my car will still hang with those. so its not worth it? where could i get all this done for cheaper
Old Jan 17, 2004 | 12:08 PM
93LSivic's Avatar
Doesnt look to me like the GEM godzilla sleeves. I may be wrong though.
Old Jan 17, 2004 | 12:22 PM
well is this 2700 worth of parts and work need to know asap. thanks on a side not the guy said golden eagle wont insure the block unless u use a copper headgasket
84mm bore
Eagle rods
ACL engine bearings
Arias Pistons
Bored and honed
Line bored
Sized rods
Modified by Prelude91siT at 9:46 PM 1/17/2004
Modified by Prelude91siT at 10:52 PM 1/17/2004
Old Jan 17, 2004 | 01:21 PM
up
Old Jan 17, 2004 | 01:48 PM
Suleman963's Avatar
ownded
Oh yah
2700 for that, DON'T GET IT. Just get new sleeves, rods, pistons, studs, and a blockguard for a B18b
Old Jan 17, 2004 | 01:51 PM
TeStUdO's Avatar
Default Re: (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Doesnt look to me like the GEM godzilla sleeves. I may be wrong though.</TD></TR></TABLE>
Yeah I would check on that maybe Vince will chime in on this post.
Old Jan 17, 2004 | 02:49 PM
The Shodan's Avatar
If its already assembled, why not... Most pay 2300 for the B-series
Old Jan 17, 2004 | 02:54 PM
Default Re: (The Shodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Shodan &raquo;</TD></TR><TR><TD CLASS="quote">If its already assembled, why not... Most pay 2300 for the B-series</TD></TR></TABLE>
if i bought it i would dissesemble it and at least plastic gauge, to many shitty machine shops out their these days
Old Jan 17, 2004 | 03:59 PM
Default Re: CHECK OUT THIS FULLY BUILT BLOCK IS IT WORTH 2700 (Prelude91siT)
Anybody else ya or na
Old Jan 17, 2004 | 04:09 PM
tegasaurus's Avatar
Sounds like an import builders block judging by the price and work (or lack there of).
-Ryan
