how did you set your cam gears boostin at 7psi
Old Jan 16, 2004 | 09:41 PM
TreLude's Avatar
Default how did you set your cam gears boostin at 7psi
97 prelude w/drag turbo kit
Old Jan 16, 2004 | 09:44 PM
roydogg's Avatar
Default Re: how did you set your cam gears boostin at 7psi (TreLude)
On the dyno will be your best bet. When your tuning you can play with your cam gears if you have alot of dyno time.
madman604's Avatar
leave it stock till you get on a dyno. every single car is different, even if you have the exact same parts.
Old Jan 16, 2004 | 09:49 PM
PHiZ's Avatar
Default Re: (Turbo E)
If you don't have a lot of dyno time, but can make 5-6 runs at the track per nite, keep a log, make settings, make runs at the track, take averages, and see what works.
-PHiZ
Old Jan 16, 2004 | 09:52 PM
horror's Avatar
Default Re: (PHiZ)
i agree dyno time is really the only way to adjust the cam gears to their optimal postion for your specific setup. i think that to many variables come into play when using the above mentioned track method
Double Agent
Jul 27, 2006 10:59 PM
rossc96
May 5, 2005 04:29 AM
b00stedbyFastrax
May 22, 2003 08:52 AM
-Whitey-
Oct 10, 2002 04:02 PM
