gauge cluster
Old Jan 16, 2004 | 06:09 PM
importpower's Avatar
Default gauge cluster
I've read about people with swaps putting gsr gauge clusters or sir clusters in their 92-95 civics. Could you just put a jdm tach face in the place of the usdm one? Or could you buy a jdm sir cluster and put a usdm speedo on it? I really want to have the correct redline and have mph.
Old Jan 16, 2004 | 06:11 PM
Ricey McRicerton's Avatar
Default Re: gauge cluster (importpower)
Swap a USDM speedo into the JDM cluster or the JDM tach into the usdm cluster. Your needles won't match, but it'll be okay.
Old Jan 16, 2004 | 07:51 PM
Default Re: gauge cluster (Ricey McRicerton)
Needles won't match?
Old Jan 16, 2004 | 08:37 PM
Discosteak's Avatar
yes because they have different types of needles
Old Jan 16, 2004 | 09:38 PM
ekb18cCivic's Avatar
Default Re: gauge cluster (BADEG6)
just get an SI cluster .. its plug and play...
Old Jan 16, 2004 | 10:12 PM
If I put a JDM tach in will the rpms be what it shows they are when driving?
Old Jan 16, 2004 | 11:42 PM
D16Z6racing's Avatar
Default Re: gauge cluster (ekb18cCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18cCivic &raquo;</TD></TR><TR><TD CLASS="quote">just get an SI cluster .. its plug and play... </TD></TR></TABLE>
Old Jan 17, 2004 | 03:16 AM
elwood's Avatar
Tach isnt right for b series.
If you just use the tach out of a jdm cluster, it will more then likely be
the white face, and that would look really stupid. If you can find
the Euro one with the black face, then you could just put the
USDM speedo in the UK cluster. That would be the easy thing to do.
But wait.......then the speedo will be white lights and the UK will be amber.
I guess you could do the colored bulbs, but it will look pretty crappy at night.
Old Jan 17, 2004 | 08:20 AM
Default Re: gauge cluster (elwood)
From what i've read on here the Si clusters don't fit 92-95. Unless your talking about Sir which reads in kilometers which I don't want.........
Are the lights attached to the gauges? Couldn't you just drop the mph speedo in for the kph and still have the correct lights because you arent switching the lights?
Old Jan 17, 2004 | 02:27 PM
bump
Old Jan 18, 2004 | 06:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importpower &raquo;</TD></TR><TR><TD CLASS="quote">From what i've read on here the Si clusters don't fit 92-95. Unless your talking about Sir which reads in kilometers which I don't want.........
Are the lights attached to the gauges? Couldn't you just drop the mph speedo in for the kph and still have the correct lights because you arent switching the lights?</TD></TR></TABLE>
You have a 92-95 Civic?
Any 92/95 Civic cluster will fit in your car. CX/VX/DX/LX/EX/SI from a 92-95 will work. Thats why peeps are saying to a get a 92/95 EX/SI cluster. Plug and play, unless you want to dea with an Integra cluster.
Old Jan 27, 2004 | 12:54 PM
Default Re: gauge cluster (D16Z6racing)
I don't want the whole cluster though. I just want the tach so it will read the 8200 redline and match a b16 swap.
Old Jan 27, 2004 | 02:17 PM
letmeseeyouskip's Avatar
buy an tach then its only about $100
Old Jan 27, 2004 | 02:51 PM
Default Re: (iiiskipiii)
Where can I find tachs individually? I was thinking of getting the sir tach which is white, then matching it with white gauges that read mph. Can you buy those indigo guages off ebay and make them use the stock lights and not that color ****. I guess i'll just buy the jdm tach and use indigo with the stock lights.
Old Jan 27, 2004 | 02:56 PM
Vero's Avatar
he means get one of those clocks with the light on it.
Old Jan 27, 2004 | 03:15 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Well, to match the b16:
It's work, but possible...write up found here:
https://honda-tech.com/zerothread?id=602325
jdmstockeg6
28
May 3, 2009 10:31 AM
cltitus
Mar 15, 2007 07:41 AM
Crunks
Jan 31, 2007 02:38 PM
714phil
Aug 31, 2005 02:16 PM
whoa its len 2
Dec 11, 2003 05:40 AM
