D16A6 swap...but only 3 mounts...can i do this?
Old Jan 16, 2004 | 11:24 AM
Project_ED8's Avatar
Default D16A6 swap...but only 3 mounts...can i do this?
i'm putting back a d16a6 into my hf crx that previously had a b series swap and they cut the front mount in order for the header to fit properly so i was just wondering if its ok to use 3 mounts(2 motor and 1 rear)??? or does the d16 need all 4? ok thanks for the help guys...
Old Jan 16, 2004 | 11:26 AM
Jet Black's Avatar
Default Re: D16A6 swap...but only 3 mounts...can i do this? (Project_ED8)
well if the B was working with 3, a d will work, it has less torque and weighs slightly less, so it should work.
Not that its too smart to run on only 3 mounts tho.
Are you sure they cut out the front mount? They may have just removed the mount, as there is a holder where the mount bolts in, if you still have the holder, you can just isntall another mount.
Old Jan 16, 2004 | 12:14 PM
96-EJ6 B18C's Avatar
Default Re: D16A6 swap...but only 3 mounts...can i do this? (Jet Black)
Yes, the motor will be fine with only three mounts. Just don't power shift or make any sharp throttle transitions.
EDIT: You may want to install the Energy Suspension inserts in the rear mount to keep it from beaking if you plan on driving the car hard.
Old Jan 16, 2004 | 12:18 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: D16A6 swap...but only 3 mounts...can i do this? (96-EJ6 B18C)
Go to the junk yard and get a front crossmember. B series mounts can get away with three mounts because they use a much harder bushing that is meant to take the beating. The stock mounts are made out of rubber and they will not last.
You will be taking a chance that is not worth taking.
old-sk0ol
Aug 8, 2008 06:25 AM
lude98SH
Jul 8, 2007 08:34 AM
CRXified
Dec 28, 2006 08:40 PM
97grnrs
Aug 13, 2006 02:21 PM
0554
10
Mar 5, 2003 10:29 PM
