DC2 wheels on Accord
Old Jan 15, 2004 | 08:16 PM
OEMaccord96's Avatar
Default DC2 wheels on Accord
Another quick question, Are the wheel diameters the same for the 96 integra R and the 94-97 accords? So if I were to purchase the R wheels I could use the tires from my accord ex oem alloys? hopefully..... Please...?
Old Jan 15, 2004 | 08:18 PM
.bagged's Avatar
Default Re: DC2 wheels on Accord (OEMaccord96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OEMaccord96 &raquo;</TD></TR><TR><TD CLASS="quote">Another quick question, Are the wheel diameters the same for the 96 integra R and the 94-97 accords? So if I were to purchase the R wheels I could use the tires from my accord ex oem alloys? hopefully..... Please...?</TD></TR></TABLE>
i suggest you purchase some new rubber for your new wheels..unless they are a low pro performance tire to begin with
Old Jan 15, 2004 | 08:24 PM
Riceburner247's Avatar
Default Re: DC2 wheels on Accord (bagged93accord)
Compare the tire sizes from the sidewall. If they are the same, you should be able to swap, but ONLY if they are the same.
Old Jan 15, 2004 | 08:28 PM
.bagged's Avatar
Default Re: DC2 wheels on Accord (riceburner247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">Compare the tire sizes from the sidewall. If they are the same, you should be able to swap, but ONLY if they are the same.</TD></TR></TABLE>
you could still swap them if the width and series tire were different as long as the diameter is the same..
Old Jan 15, 2004 | 08:37 PM
iam7head's Avatar
but dont go too low profile, if the car is dropped more than 2inch, 15 with low pro=very low..
I am picking up my itr 96 rims tonight
you'll end up buying a set of spacer, the offset is wrong
Old Jan 15, 2004 | 08:51 PM
4genaccordfreak's Avatar
and as long as the bolt pattern is the same
4x114.3
Old Jan 15, 2004 | 09:01 PM
iam7head's Avatar
Default Re: (4genaccordfreak)
https://honda-tech.com/zerothread?id=328521
Old Jan 15, 2004 | 09:37 PM
Default Re: (iam7head)
can you explain to me the whole wheel spacer deal
Old Jan 15, 2004 | 11:55 PM
iam7head's Avatar
Default Re: (OEMaccord96)
ah..the offset of the rims that originally designed for itr is too small for a family car-the accord.
I am getting info from a accord 4th gen owner, which happens to owned a set of ITR96 spec rims before telling me that i could get away by shaving the front brake caliper to get the proper clearance.
I am guessing it's time to break out the dremel
well, I am picking up my itr rims and spacers very soon and I'll let your know once i got them on
ah..if everything works great, tomorrow afternoon
my car is a 4 banger six generation accord btw
Old Jan 16, 2004 | 04:26 AM
urbanlegend21's Avatar
New User
ITR tires are 16"
Accord wheel size is 15"
Old Jan 16, 2004 | 08:33 AM
iam7head's Avatar
Default Re: (urbanlegend21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanlegend21 &raquo;</TD></TR><TR><TD CLASS="quote">ITR tires are 16"
Accord wheel size is 15"</TD></TR></TABLE>
96 spec itr rims are 4x114.3 15x6.5 come only in CW color by enkei
which fits an accord with a little help from a spacer or shaved caliper bracket.
97+ itr sports 5x114.3 a 16" rims with gunmetal or CW, same for canadian model
Old Jan 17, 2004 | 01:15 AM
iam7head's Avatar
http://www.imagestation.com/album/?id=4287983645
Picked up my set of 96 spec itr rims from a socal H-T seller for a pretty fair price
just spend an hour or so washing it with simple green and end up waxing everything..
worthless picture of my suspension and bling bling lugs
Moneyshot
as for offset concern, there's a very minor clearance from the spoke of the rims to the brake pad housing/bracket, accord93ex educated me that i could just shave the housing a bit, but I am thinking a 3mm spacer.
the back fits like a glove
car=cg3 4cyl coupe
edited: additional pic
Just want to show you guy the detail of the center cap, it's amazingly beautiful red "h" with very high metallic flask in the paint, surround by CW
Modified by iam7head at 2:30 AM 1/17/2004
Old Jan 17, 2004 | 04:18 PM
iam7head's Avatar
https://honda-tech.com/zerothread?id=737178
Finally got them mounted, i end up using a 3mm spacer, fits like a glove, even with my Meaty tires
a little OT preview
Old Jan 18, 2004 | 01:10 AM
Broken Gearbox's Avatar
looks good
Woody.
Feb 15, 2015 04:49 PM
naicul
Jun 23, 2008 09:42 AM
squareback
Mar 28, 2006 06:02 AM
AccordCD5
Jun 11, 2004 05:52 AM
crafty
Nov 10, 2003 03:14 PM
