Changing Tranny Oil???
Old Jan 15, 2004 | 06:56 PM
93EH6
Guest
Posts: n/a
Default Changing Tranny Oil???
Does anyone have a how to on changing tranny oil i heard you are supossed to use the same oil as you do for you engine (guy at autozone told me so i am not sure) but i don't know where to drain it or where to fill any help is appreciated
Old Jan 15, 2004 | 06:57 PM
sting94112's Avatar
Default Re: Changing Tranny Oil??? (93EH6)
you can use 10w30. but i use honda manual tranny fluid
http://www.c-speedracing.com/h...d.php
Old Jan 15, 2004 | 07:02 PM
W C L's Avatar
use honda mtf or 10w3, 5w30 up to u.... when u are underneath the tranny lookin it at, there is a bolt that has a 3/8 indention in it, that is the drain bolt, stick your racthet it in there break it loose....
to fill it i cheat and take out the Vss sensor and get a long funnel and fill it through the vss hole so i don have to pump it for the next 20 mins.... or u can use a pump and pump about 2.5 qts in it through another bolt right above the drain plug.... if that doesnt help do a search
Old Jan 15, 2004 | 07:03 PM
RyanEJ8's Avatar
Use Honda MTF. Get a Helms manual, tells you how to do any work on your car.
Old Jan 15, 2004 | 07:07 PM
The Internet Tough Guy's Avatar
Default Re: Changing Tranny Oil??? (RyanCivic2000)
a simple search found this: https://honda-tech.com/zero...age=2 there's a nice pic on page 2
don't use motor oil, get honda mtf, redline mtl, or gm syncromesh. also, fill it through the vss on top instead of the fill bolt - it's much easier.
next time, search before you make a thread
Old Jan 15, 2004 | 07:15 PM
Snail Tuning's Avatar
their should be a drain plug at the bottom of the tranny, unscrew it and drain your fluid, on top their should be a hole to fill it back up with. if not i just pull the VSS sensor and fill it in that hole. very easy because its a big hole to put a funnel in.
don;t use engine oil. on domestics yes its fine. on imports use oem.
get honda tranny fluid or redline tranny fluid.
htf works great, and if u have LSD just get a cheap LSD additive from autozone and add till your lsd chatter goes away.
their should be a bolt cose to the axle unscrew it and when the fluid is level with the hole. your tranny is filled. hope this helps.
Old Jan 15, 2004 | 07:16 PM
93EH6
Guest
Posts: n/a
Default Re: Changing Tranny Oil??? (jwn7)
thanks guys
Old Jan 15, 2004 | 07:17 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote"> Get a Helms manual, tells you how to do any work on your car. </TD></TR></TABLE>
thank you!why will people spend all this money on modding their car,but won't spend $70(or even DL it for free) on a manual that tells them how to do ANYTHING to their car?!at least half the questions asked on this forum could easily be answered by looking in an shop manual.it's the same as the people who cry because their $30k civic got stolen,but they didn't even have an alarm.
i think it's time to adopt a new smiley on here: :rtfm:
chris *who thinks that when you register your car at the DMV,you should be given an alarm system and shop manual*
cxSHOE's Avatar
get the helms from my sig and refill the transmission oil by taking out the vss. much easier than doing it from the side... there is a write up on here somewhere.
Old Jan 15, 2004 | 07:57 PM
Ricey McRicerton's Avatar
Default Re: Changing Tranny Oil??? (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
chris *who thinks that when you register your car at the DMV,you should be given an alarm system and shop manual*</TD></TR></TABLE>
Hell yes!! You sir are correct. for that!
Old Jan 15, 2004 | 08:05 PM
Default Re: Changing Tranny Oil??? (Ricey McRicerton)
hahahah... man if i could have an avatar, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
i agree 100%
Old Jan 15, 2004 | 08:11 PM
BauleyCivic's Avatar
Risky Business
GM Synchromesh Friction Modified
Part # 12377916
Old Jan 15, 2004 | 08:14 PM
thenick's Avatar
Default Re: Changing Tranny Oil??? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">GM Synchromesh Friction Modified
Part # 12377916</TD></TR></TABLE>
planning on running this along with some ES bushings
0 degree weather notchy shifts own me
Old Jan 15, 2004 | 08:40 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Hell YES.
Einhander276
17
Jun 26, 2010 07:22 PM
xlusiveracer
19
Feb 5, 2007 05:57 PM
Silent_Destruct
Mar 26, 2006 01:07 AM
SHG_Beans
10
Jan 22, 2006 12:21 PM
elevatethis
15
Dec 30, 2003 09:16 PM
