O.K., turbo timer w/factory 99civic si keyless/alarm???!!!!
Old Jan 15, 2004 | 06:40 PM
ocd's Avatar
ocd
Default O.K., turbo timer w/factory 99civic si keyless/alarm???!!!!
I have been searching all over the net looking for some help getting the keyless entry to lock the doors while engine is turbo timing down. I can't find anything anywhere. It's the factory keyless. Any help will be appreciated. It's a 99 si.
thanks.
Old Jan 15, 2004 | 06:42 PM
Hoodwinked's Avatar
Default Re: O.K., turbo timer w/factory 99civic si keyless/alarm???!!!! (ocd)
i have the same problem
Old Jan 15, 2004 | 06:46 PM
ocd's Avatar
ocd
Default Re: O.K., turbo timer w/factory 99civic si keyless/alarm???!!!! (Hoodwinked)
I've looked all over the net. I can't believe no one has a how to. If I find it, I'm gonna host a how to page for this topic.
Old Jan 15, 2004 | 07:06 PM
JDEM1's Avatar
i have the same problem unresolved as well, i dont think there is anything possible with the factory alarm
Old Jan 15, 2004 | 07:47 PM
rjardy's Avatar
Default Re: O.K., turbo timer w/factory 99civic si keyless/alarm???!!!! (JDEM1)
http://boosted-hybrid.com/viewtopic.php?t=37
Thank you, thank you...
Rob
Old Jan 15, 2004 | 07:55 PM
Hoodwinked's Avatar
Default Re: O.K., turbo timer w/factory 99civic si keyless/alarm???!!!! (rjardy)
praise!
Old Jan 15, 2004 | 08:20 PM
JDEM1's Avatar
i read through it, it was done on a turbo type r with alpine aftermarket alarm, factory keyless is VERY different, i still dont believe it will work, and that info is not detailed enough, but thanks
Old Jan 15, 2004 | 09:58 PM
rjardy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDEM1 &raquo;</TD></TR><TR><TD CLASS="quote">i read through it, it was done on a turbo type r with alpine aftermarket alarm, factory keyless is VERY different, i still dont believe it will work, and that info is not detailed enough, but thanks </TD></TR></TABLE>
just keyless? as in no alarm? or the silly horn alarm?
Rob
Old Jan 15, 2004 | 11:11 PM
LiLOtaku's Avatar
I have a 99 Si myself.
I just usually lock my door with the key's and it'll lock both doors regardless.
Not really that big of a deal. The only time your gonna have to worry about it is if you have a car alarm.
Old Jan 16, 2004 | 05:36 AM
mike1114's Avatar
Default Re: O.K., turbo timer w/factory 99civic si keyless/alarm???!!!! (LiLOtaku)
I thought 99 Si's had alarms????
Anyway, check this site out, this guy said he got it to work on 95 integtra with factory alarm.
I didn't read through that well but I did see that it works for other honda's too.
http://importnut.net/turbotimer.htm
Old Jan 16, 2004 | 03:11 PM
JDEM1's Avatar
Default Re: O.K., turbo timer w/factory 99civic si keyless/alarm???!!!! (mike1114)
yeah thats the page i used to help me install my timer, hes saying that the factory alarm can function with the addition of the timer, BUT it will not self lock after the timing is over, thats where im getting at, and i still doubt the possibility..
Old Jan 16, 2004 | 06:38 PM
ocd's Avatar
ocd
Guys, I give up. That "import nut" website doesn't explain how he made it work with the alarm. He only says that he did make it work. He doesn't state if it is aftermarket alarm of OEM. I called a very reputable audio store and they didn't know. They told me they have all had problems locating the unit that actually controls the OEM alarm functions. They thought it was in the factory radio - wrong! They think some function may be embedded in the ecu and may not be able to be bypassed.
Thanks anyway.
Old Jan 16, 2004 | 07:00 PM
JDEM1's Avatar
gotta get an aftermarket alarm to work with tt
Old Jan 16, 2004 | 08:36 PM
B18bEK's Avatar
https://honda-tech.com/zerothread?id=437044
civic_turbo_wannabe
Oct 7, 2008 06:20 AM
CAE
Feb 12, 2005 11:16 PM
EJ1 wilcox
Audio / Security / Video
Jan 13, 2005 10:52 AM
boostincoupe
Jul 8, 2003 07:19 AM
Erik_Pb_Foot
Mar 7, 2002 08:07 PM
