Suspension issues...
Old Jan 15, 2004 | 05:23 PM
1998 hatch dx's Avatar
Default Suspension issues...
I recently hit a curb in my 98 ek hatch ( at about 70 ) i bent the control arm, and another piece...im not sure what it's called, it attaches to the control arm and goes toward the back of the car and attaches to a bushing...help me out...what is this part called, anyone know where i can these parts?
Old Jan 15, 2004 | 05:44 PM
Kendall's Avatar
You can probably find the parts in a junk yard, or contact Larry Jr. at Import Auto Salvage in Marion NC, he'll be able to help you.
Old Jan 15, 2004 | 06:55 PM
kommon_sense's Avatar
Default Re: (Kendall)
sounds like you are describing the lower control arm. If you have to swap arms, I'd recommend you go with either the ex front setup or SI front setup and get a front sway bar out of the deal. i believe that ImportAutoSalvage sells the SI front sway-bar setup for about $170. Good deal since you have a dx. However the 22mm front sway from the EX may be a better choice.
Old Jan 15, 2004 | 07:01 PM
b16si's Avatar
Default Re: (kommon_sense)
Look for the aftermarket control arms that will make it so you can fit wider wheels here is a pic you can find them on ebay for about 90 bucks.
Old Jan 15, 2004 | 07:02 PM
b16si's Avatar
Default Re: (b16si)
well heres a link the pic didnt work obviously http://cgi.ebay.com/ebaymotors...29919
Old Jan 16, 2004 | 03:34 PM
sick64nova's Avatar
Default Re: Suspension issues... (1998 hatch dx)
it is part or the lower control arm also caller a radius rod
ekim952522000
21
Jan 5, 2026 11:21 PM
unclematt
12
Aug 27, 2016 09:59 AM
krkline2gdsm
Suspension & Brakes
Oct 26, 2007 05:25 AM
pliskin679
Suspension & Brakes
Apr 30, 2007 01:10 PM
AMLS4dr200whp
Suspension & Brakes
Dec 6, 2005 07:15 PM
