Which sway bars to buy? Neuspeed, Eibach, ST
Old Jan 15, 2004 | 05:06 PM
steronz's Avatar
Default Poll: Which sway bars to buy? Neuspeed, Eibach, ST
The car is an 89 CRX Si. I've included approximate prices since cost is a factor. I can afford the Eibachs and Neuspeeds, but if they're not much better than the STs, I'd rather not put a needless strain on my wallet.
Old Jan 15, 2004 | 05:13 PM
SoulSurfer's Avatar
Default Re: Poll: Which sway bars to buy? Neuspeed, Eibach, ST (steronz)
I'd say go for the ST's and save $120. Then replace the rubber anti-roll-bar bushings with solid bushings.
Check out this page.
http://www.ef-honda.com/ben/
Go to "TECH" and then "Make your rear sway bar more effective."
Old Jan 15, 2004 | 05:21 PM
1's Avatar
Default Re: Poll: Which sway bars to buy? Neuspeed, Eibach, ST (SoulSurfer)
Progress adjustable.
Old Jan 15, 2004 | 06:44 PM
hatchblack's Avatar
Well, i don't know how they will compare, but i have the progress technology 22mm sway bar on the back of my 89 civic si and i bought the 23 mm sway bar from the front of a 90-92 integra gsr from the dealer. i got the rear bar for $190 ish bucks including s&h and the front bar from the dealer with mounting hardware for $100. i love the setup and would recommend it. so for a few more bucks, you could have a front bar that weighs literaly like five pounds. i think the plastic wrap was heavy than the bar. the front bar was a direct bolt up, and the rear bar was real easy to install.
Old Jan 15, 2004 | 07:13 PM
SpoonFedEF7's Avatar
Default Re: Poll: Which sway bars to buy? Neuspeed, Eibach, ST (hatchblack)
sorry to ***** in this thread but would the front sway bar from a 90-92 gsr work on a 90 crx si?
Old Jan 15, 2004 | 07:21 PM
wannab20hatch's Avatar
Default Re: Poll: Which sway bars to buy? Neuspeed, Eibach, ST (SpoonFedEF7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedEF7 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to ***** in this thread but would the front sway bar from a 90-92 gsr work on a 90 crx si?</TD></TR></TABLE>
Yes i have a 90-93 ls integra sway bar on my 91 std. Hey spoonfedef7 is your name wes? My buddy bought that black crx si from you.
Old Jan 15, 2004 | 07:36 PM
Default Re: Poll: Which sway bars to buy? Neuspeed, Eibach, ST (wannab20hatch)
yeah that's me. Hey any chance you guys want to buy my rims 16" Konig Rated-R's with tires for $350
Old Jan 15, 2004 | 07:37 PM
anyone know of any stock rear sway bars that are bigger than a crx si's and will work on the si
Old Jan 15, 2004 | 07:45 PM
whizdumb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedEF7 &raquo;</TD></TR><TR><TD CLASS="quote">anyone know of any stock rear sway bars that are bigger than a crx si's and will work on the si</TD></TR></TABLE>
Good question, I would also like to know the answer. Also do you have to have Si LCAs for the sway bars to mount up?
Old Jan 15, 2004 | 08:27 PM
Default Re: Poll: Which sway bars to buy? Neuspeed, Eibach, ST (shiznattik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedEF7 &raquo;</TD></TR><TR><TD CLASS="quote">yeah that's me. Hey any chance you guys want to buy my rims 16" Konig Rated-R's with tires for $350</TD></TR></TABLE>
Ill ask some friends. I would but i bought a 240 and now have 5 lugs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiznattik &raquo;</TD></TR><TR><TD CLASS="quote">
Good question, I would also like to know the answer. Also do you have to have Si LCAs for the sway bars to mount up?</TD></TR></TABLE> You can use a 90-93 integra rear sway bar on an ef. Yes you need to have si lca's for it to mount up or have an integra disc brake conversion.
Old Jan 15, 2004 | 10:10 PM
how much bigger is the teg rear sway bar from the ef's
tweek_boii
19
Nov 13, 2009 06:31 AM
ilvi3tkidxx
Feb 27, 2009 01:24 AM
dj12oclock
Honda Civic (2006 - 2015)
Mar 19, 2008 12:19 AM
Rick hybrid
Honda Civic (2001 - 2005)
Oct 14, 2007 06:24 PM
Vinceg99
Jan 10, 2003 10:56 AM
