problem takin off lower timing cover
Old Jan 15, 2004 | 03:33 PM
tuan...'s Avatar
Default problem takin off lower timing cover
i got all the bolts needed to take off the lower timing belt cover and i ran into another problem. there is the a rod sticking out near the motor mount. i dunno wat it is called. it has grooves in it and looksl ike a 10mm wrench can fit on it. that thing is preventing me from pullin off the timing cover. i cant pull the cover around it. not sure if that is enuff detail for u guys to noe wat it is, but help is appreciated. thanks
Old Jan 15, 2004 | 03:44 PM
Joon525's Avatar
Default Re: problem takin off lower timing cover (h22poweredgsr)
Can you point it out here?
Old Jan 15, 2004 | 03:47 PM
4bidden's Avatar
Sounds like the maintenance bolt to me?
Old Jan 15, 2004 | 03:55 PM
tuan...'s Avatar
not too sure, but i think its #32
it sticks out to the rite of the motor mount.
Old Jan 15, 2004 | 03:59 PM
Joon525's Avatar
Default Re: (h22poweredgsr)
I'll go look right now and see if I can come up with an answer for you.
EDIT: It is the maintenance bolt. It should have a lockpin on it that you must remove before pulling off the lower ocver. There should be a rubber seal there too (don't lose that). Just below the mount there's another seal that goes on the adjusting nut for the tensioner by the way.
Old Jan 15, 2004 | 04:21 PM
tuan...'s Avatar
yea i took that pin out, still wont come out. i think its cus i have a pretty tite fit in the integra bay. =/ now im screwed? can i cut the thing?i pull it out by going down rite?
Old Jan 15, 2004 | 05:02 PM
tuan...'s Avatar
can i cut the maintenace bolt off?>
Old Jan 15, 2004 | 05:08 PM
Revi's Avatar
Default Re: (h22a4_dc2)
DOnt cut anything! As long as you got the bolts and lock pin out, the cover should come off. IF its not, make sure nothing else is making contact. Never cut anything or force anything out. Thats how your break things and end up in deeper ****.
Old Jan 15, 2004 | 05:09 PM
tuan...'s Avatar
u jus dont undertsand, its in an integra and ther eis no room for the timing cover to just "slip" off. i gotta cut sumthing
Old Jan 15, 2004 | 05:29 PM
4bidden's Avatar
Well then you're F'd man. You cant cut that bolt off and it wont come out unless the tensioner pulley comes with it.
Should have just went with a B18.
Old Jan 15, 2004 | 05:37 PM
H23vtecEG's Avatar
Default Re: (4bidden)
try taking it out when the motor is in an EG. not very spacy
Old Jan 15, 2004 | 05:54 PM
GruvyTune's Avatar
New User
Default Re: problem takin off lower timing cover (h22a4_dc2)
listen...
that bolt is only to prevent the tensioner from moving. You DONT remove that bolt. if you force it, you'll snap it off where it bolts into the water pump. You WILL be able to remove the timing cover if you remove that rubber grommet around that maintanance bolt.
Old Jan 15, 2004 | 06:09 PM
Revi's Avatar
Can you take some motor mounts off and lift or lower the motor enough to give you more room to work with? I know in the prelude you can take off the driver side motor mount and you can lower the engine some, just make sure when you do this you dont put strain or pull any hoses.
What is it your trying to do? Change the T belt?
Old Jan 15, 2004 | 07:26 PM
tuan...'s Avatar
i tried to the crank gear to set my engine to tdc and to take out my old timing belt ( i ripped it while tryint to take the crank pulley off, it got stuck and squished *whoops) I dunno if this is odd or not but, my tensioner bolt was on the outside of my timing cover (i needed to take the bolt out before i could get the timing cover off). is this normal or not?
Old Jan 15, 2004 | 07:43 PM
Joon525's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a4_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">I dunno if this is odd or not but, my tensioner bolt was on the outside of my timing cover (i needed to take the bolt out before i could get the timing cover off). is this normal or not?</TD></TR></TABLE>
Normal.
Old Jan 16, 2004 | 06:30 AM
tuan...'s Avatar
how do i adjust a auto tensioner?? heh im using an integra manual is it has a manual tensioner and it confused me for awhile, heh.
Old Jan 16, 2004 | 08:48 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
why they have to make it difficult to take that dang cover off.....maybe its made so that stupid people cant take it off....i guess that includes me...hahah...who cares....
Revi's Avatar
the auto tensioner adjusts it self, the only thing is if taken out it will have to be re-compressed and held at that position to be able to put it back on. All you have to do is remove the bolt (Make sure no oil spills out) and get a screw driver and turn it so the tensioner compresses. Then you have to hold it like that, there is a special metal bracket that comes with it when you buy one but ive also heard of people holding it down with a zip tie?
If you look at the picture above, its the metal thing on #25
Old Jan 16, 2004 | 08:59 AM
tuan...'s Avatar
wat is # 10?
Old Jan 16, 2004 | 02:21 PM
DarkJedi's Avatar
on a prelude its hard to take the lower cover off too.. what you need to do is loosen up the side motor mount so it will drop the engine to the side a bit enough to slip the cover off, this is what the service manual says, its easy to do, works like a charm every time
Old Jan 16, 2004 | 03:03 PM
tuan...'s Avatar
well too late now, haha.
mossberg
Aug 21, 2018 04:44 PM
mem94043
May 16, 2011 12:28 PM
BB6racer
Nov 19, 2007 07:05 PM
NSfit
Nov 28, 2006 09:48 AM
