Aw, crap. PS pump leaking.
Old Jan 15, 2004 | 01:34 PM
MK Ultra's Avatar
Default Aw, crap. PS pump leaking.
I've noticed a hint of PS noise occasionally in the last couple of weeks. Come to find out the stupid thing is leaking.
For now, I'm just going to add fluid as needed, but eventually I'll have to do something about it. Not sure if I'll just remove the system and loop it or if I'll attempt to rebuild the pump.
Has anyone here rebuilt an Integra PS pump? Is there a kit available, or will I be stuck having to buy an entire rebuilt unit?
Old Jan 15, 2004 | 02:14 PM
rated_r's Avatar
Default Re: Aw, crap. PS pump leaking. (doosu)
put ps Lucas in it... It stopped the leak.. Its a good tempory fix
Old Jan 15, 2004 | 02:17 PM
MK Ultra's Avatar
Default Re: Aw, crap. PS pump leaking. (rated_r)
The leak is pretty small, so my temporary fix will be simply adding fluid as needed. I'm a bit leary of the Lucas stuff because if I end up rebuilding the pump I don't want something in there gumming up the works. The Lucas stuff probably is an agent that causes rubber seals to swell, which might make my job more difficult.
Old Jan 15, 2004 | 04:49 PM
rtype11's Avatar
bud answer to your problems I am selling a PS with AEM underdrive pulley. 20plus shipping, there is a pic on my for sale thread if interested.
Old Jan 15, 2004 | 04:51 PM
b19coupe's Avatar
Power steering pumps are rebuildable. Done a few.
Old Jan 15, 2004 | 05:02 PM
Kendall's Avatar
JUN.R is also selling his power steering equipment, and I'll be selling mine here in a few weeks.
Old Jan 15, 2004 | 05:10 PM
len's Avatar
len
What's a PS pump?
Old Jan 15, 2004 | 05:13 PM
Dropspeed's Avatar
Default Re: Aw, crap. PS pump leaking. (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">What's a PS pump?</TD></TR></TABLE>
Its what creates flab in your arms
Mattj
Old Jan 15, 2004 | 05:22 PM
splitime's Avatar
Default Re: Aw, crap. PS pump leaking. (Dropspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dropspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Mattj</TD></TR></TABLE>
Ummmm flab....
&lt;--- who's car never came with PS
Old Jan 15, 2004 | 06:19 PM
mstewar's Avatar
you could probably pick a used one up off here easily as others have mentioned. I'll probably be selling mine soon..
Old Jan 15, 2004 | 09:22 PM
JjuuN R's Avatar
yeah let me know if you want it, would rather sell it complete rather then just the pump though.
&lt;-- who wishes his car never came with it
Old Jan 15, 2004 | 10:17 PM
MK Ultra's Avatar
Default Re: (JUN.R)
Thanks. That's a great offer, but I won't be able to take advantage of it. Chances are I won't mess with it until summer.
Oh, and this is a real pisser, my apartment complex prohibits tennants from working on their vehicles on the premises.
Old Jan 15, 2004 | 10:44 PM
JjuuN R's Avatar
Default Re: (doosu)
usually if you know of any shops in town and are in good terms with them, they probably won't mind you working on your car in one of thier bays if it's something that's not going to take up a ton of time or something
Old Jan 16, 2004 | 12:06 PM
BlackAckeR's Avatar
Default Re: (JUN.R)
How often do you guys have to add PS fluid!?!... Does it need to be checked on a regular basis?
Old Jan 16, 2004 | 12:58 PM
MK Ultra's Avatar
Default Re: (BlackAckeR)
All fluids should be checked at least as frequently as you change the oil.
Until now, I haven't had to add PS fluid, but it's always a good idea to keep an eye on fluid levels.
Old Jan 16, 2004 | 02:32 PM
rtype11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackAckeR &raquo;</TD></TR><TR><TD CLASS="quote">How often do you guys have to add PS fluid!?!... Does it need to be checked on a regular basis?</TD></TR></TABLE>
its a sealed system, so never has to be filled unless your leaking, so I think I am trying to say its not a maintenance item.
Old Jan 16, 2004 | 10:01 PM
MK Ultra's Avatar
Default Re: (rtype11)
It is not a sealed system. You can check the fluid level by looking through the body of the reservior, which is marked for minimum and maximum levels. Fluid can be added by removing the red cap on top of the reservior.
moonchies
Aug 11, 2017 03:03 PM
Luward
Honda CR-V & Element
Nov 27, 2010 12:25 PM
darockstar
Apr 24, 2006 05:50 AM
btran
Jul 29, 2004 09:16 AM
zijiejijeijrkjk
Mar 15, 2002 05:28 AM
