VAFC Best Fix for CEL Caused by Oil Pressure Sensor
I have a 00 euro accord type r motor in an eg hatch back and it throws the cel, code is for the vtec oil pressure sensor. My question is instead of buying the sensor can I just solve my problem with a VAFC?
not with a vafc. But a euro/jdm ecu will probably do it. Or you can tie the vtec oil pressure signal wire into the vtec solenoid wire...
-PHiZ
-PHiZ
Since the car was re-wired to obd1 I am using a p28 import builders ecu, I am not to sure if that is considered a jdm ecu. Would you solder the wires together or just splice and tape? thanks
topsekret
Dec 24, 2002 01:22 PM
